It is currently Wed Nov 04, 2026 8:09 pm
Post Posted: Tue May 03, 2011 8:59 am
well i put a 2 inch body lift in the other day and now im not sure if there related but the car wont start .. it turns over but no starting ? :S
when i lifted the car i did pull off the big battery clamp wire off the battery .. but i fixxed that but yer .. any ideas thanks
also i do know i need to change my spark plugs and leads latly its been starting on 3 cyld then when it warms up the 4th works
Post Posted: Tue May 03, 2011 9:01 am
Did you put it back on correctly/tightly? Earth from engine to body still there?
Post Posted: Tue May 03, 2011 9:02 am
Rusho wrote:
Did you put it back on correctly? Earth from engine to body still there?
earth from engine to body wheres that ?
Post Posted: Tue May 03, 2011 9:13 am
Did you check you're getting spark? $10 says coil is disco'd
Post Posted: Tue May 03, 2011 9:14 am
x2.. i would ay you have accidently pulled a wire off the coil
Post Posted: Tue May 03, 2011 9:36 am
Spot on the money thanks guys :)
Users browsing this forum: No registered users and 230 guests
