It is currently Tue Sep 22, 2026 1:25 pm
Vehicle: LWB Sierra & XL7
Post Posted: Tue May 03, 2011 12:12 pm
I got myself a Fog light switch, but am wondering what wire is what. The wiring diagram in the workshop manual is giberish.
Post Posted: Tue May 03, 2011 12:22 pm
dash lights
earth
switch to operate only when headlights are on
power in
switched out
dont know what order tho, have you got a multi meter?
Go Hard, Trailer Home
Post Posted: Tue May 03, 2011 12:30 pm
Each time I play with a multi meter, I blow them up, But I can work a mean test light ;)
I was thinking of using it for front fog lights.
'92 Vitara & Camper trailer
Post Posted: Tue May 03, 2011 10:28 pm
I need to get rid of the operate only when lights are on wire, so my LED reverse lights can be used without lights on.
Post Posted: Tue May 03, 2011 10:46 pm
Wouldn't be easier to add a simple over ride switch, that way they can be manually on or automatically activated. ?
Post Posted: Tue May 03, 2011 10:49 pm
Find the wire that switches with the lights on and change it to a reverse light wire?
Post Posted: Tue May 03, 2011 11:04 pm
I have them via the fog switch so that i can just flick them on when i need them, i only use them when reversing down my long narrow driveway.
Theyre quite bright, and dont need them on all evrytime i reverse.
Post Posted: Tue May 03, 2011 11:24 pm
If they are bright, cool, keep them as a individual light that you can manually turn on. This way, those lovely people who drive up your arse with high beam can be told.
Post Posted: Tue May 03, 2011 11:52 pm
then find the lights on power input (hopefully its seperate to teh internal illumination wire and change it to either have power all the time or power with ignition
Post Posted: Wed May 04, 2011 4:47 am
You know they have a 2 Fuses in them right???
Stocker
Post Posted: Tue May 08, 2012 7:45 am
Hi all,
Looking at installing a pair of foglights into my 91 vitara jlx, it already has the button there for the fog lights. Not sure whether it is wired in.
If it is what wires do I hook the fog lights up to?
Post Posted: Tue May 08, 2012 1:56 pm
Button will turn on the lights in the rear bumper, you'd have to run new wiring to the front.
Users browsing this forum: Google [Bot] and 166 guests
