It is currently Thu Oct 08, 2026 6:53 am
Post Posted: Thu May 05, 2011 7:55 am
hey, so just wondering how to go about lifting my 89 vitara. already has a suspension lift but wanting to lift the body. i have found stuff on manuals but mine is a auto. do i have to lift the gear box and how do i do it. any info would be great, thanks guys
Post Posted: Thu May 05, 2011 8:12 am
No, the trimatic auto is cable shifted so it's actually easier than body lifting a manual is the gearlever won't get tight on the console due to the bigger gap between the gearbox and body.
There's no need to lift the auto.
Post Posted: Thu May 05, 2011 8:30 am
just the usual mods to the transfer lever, which i found easiest to do by just cutting off the old one, and welding on some windmill rod, and bending to suit, cos the factory stuff is sooo hard to bend
Post Posted: Thu May 05, 2011 9:02 am
thanks heaps. so would you reckon 2inches is too much or just a 1 inche. i want the least hassle
betty...fiesty grandma
Post Posted: Thu May 05, 2011 9:09 am
1" and 2" are exactly the same amount of hassle - If you are unbolting and fiddling with everything, just go 2" from the outset.
Post Posted: Thu May 05, 2011 10:03 am
i've been told to ask about what i can use to join the original bolt to longer or bolts or are the bolts removable?
Post Posted: Thu May 05, 2011 10:17 am
Suzuki's run a captive body stud & you need a female bolt to thread onto the body stud.
BYE Products make a good kit for the Vitara http://auszookers.com/index.php?name=Fo ... ic&t=15518
Post Posted: Thu May 05, 2011 10:18 am
What body lift kit are you using? I assume you are talking about the fixed threads? If you use the Just_Cruizin kit then everything is supplied, including female bolts to fit the threads and detailed instructions
Post Posted: Thu May 05, 2011 10:37 am
Yeah just use a Just Cruisin lift or similar, the female bolts are the best way
Users browsing this forum: Google [Bot] and 140 guests
