It is currently Tue Oct 06, 2026 9:45 am
Vehicle: Vitara 1995
Post Posted: Thu May 05, 2011 10:21 am
I have been trying to manually remove the camshaft sprocket. No hope....
Looking at buying one of those cheap $50 Aldi or Bunnings rattle guns. Think they are electric (hope they aren't air).
Are they strong enough thou? Think they are about 500watt and 150mn or something like that.
Post Posted: Thu May 05, 2011 10:23 am
Should be easy as pie. Is the belt still on?
Post Posted: Thu May 05, 2011 10:24 am
Use a breaker bar with a piece of pipe as an extention. Rest it against the chassis rail, remove the ignition lead and tap start once with the ign key. Should crack it. Make sure the breaker is on the right side of the engine bay though, as you will make a mess otherwise :lol:
Post Posted: Thu May 05, 2011 10:26 am
Alrite for crank bolt but not as easy for cam.
Post Posted: Thu May 05, 2011 10:30 am
it isn't in the car.
I could not loosen the sprocket bolt, so I moved on and have already removed the crank pulley & belt. Those were piss easy.
Last edited by bristlenose2008 on Thu May 05, 2011 10:42 am, edited 1 time in total.
Post Posted: Thu May 05, 2011 10:31 am
I've gotten it to work before.
But it is a long way to the rail. I just use a snap off rattle gun these days. 700Nm in reverse is usually enough :wink:
Post Posted: Thu May 05, 2011 10:34 am
I got mine off once with a shifter...
Post Posted: Thu May 05, 2011 10:36 am
Likewise on the rattlegun, but mines a Wurth (slightly better :P )
I have had limited success with wedging a lever bar or big screwdriver between one of the small bolts that hold the cover on behind the sprocket and the sprocket itself. You'll need a fairly long breaker bar for this
Post Posted: Thu May 05, 2011 10:46 am
shite.........700Nm, that may be a little more than the $50 I was looking at spending tomorrow.
Think I will have to hire one.
Post Posted: Thu May 05, 2011 10:48 am
mmm wurth rattle gun, used one yesterday.. very nice and lots of nuts :D
Post Posted: Thu May 05, 2011 10:54 am
ajsr .... the two before you were enough tease already!
I really need this shit off ASAP, I have to drop the cam shaft , crank shaft and block off at the machinist on Friday afternoon.
Damn it....
Post Posted: Thu May 05, 2011 11:00 am
Why do you need to take just the cam to the machinist? just get him to take it out.
like scrawn said you can wedge teh pulley and do it with a spanner (really its not tight but being impatient has made life difficult) but its easy to bend the pulley
and my Atlas Copco gun shits on you lots pissy little things, they know about stuff with air :wink:
Post Posted: Thu May 05, 2011 11:13 am
Compensating for your short stature maybe? :thefinger:
Post Posted: Thu May 05, 2011 11:22 am
Yup Wurth Premium Rattle Rated at 1,990Nm reverse from the top of my head.
Let me know if you want one :lol:
Vehicle: Nissan
Post Posted: Thu May 05, 2011 12:18 pm
:wink: :wink:
is this the lil devil http://www.wurth.com.au/catalogueview.a ... 2_0003.pdf
Pearce-toff Racing
Post Posted: Thu May 05, 2011 12:29 pm
:wink: :wink:
Can't be. That one only has 800Nm in reverse.
Vehicle: Nissan
Post Posted: Thu May 05, 2011 12:33 pm
huh they dont list any others... :?
Pearce-toff Racing
Vehicle: 4wd
Post Posted: Thu May 05, 2011 12:37 pm
It's the 3/4" one.
Watch out or you'll get sued.
Vehicle: 4wd
Post Posted: Thu May 05, 2011 12:40 pm
This one http://www.wurth.com.au/catalogueview.a ... 2_0004.pdf
Vehicle: Nissan
Post Posted: Thu May 05, 2011 12:44 pm
stockman wrote:
8O bit big for me...
Pearce-toff Racing
Post Posted: Fri May 06, 2011 5:29 am
in case anyone is interested how this is going.....I have managed to break the size 17 socket & bought a replacement one a few hours ago. My first Sidchrome brand of tools.
Only issue is I am borrowing an air compressor and an impact wrench tomorrow morning, and apparently the Sidchrome socket can easily break when using it on a rattle gun/impact wrench. Guess we will see tomorrow.
Post Posted: Fri May 06, 2011 5:35 am
Arn't they unconditionally guarantied.
Post Posted: Fri May 06, 2011 5:41 am
thats why they make impact sockets :wink:
Post Posted: Fri May 06, 2011 5:49 am
Only till you break them then the warranty runs out :evil:
Vehicle: Nissan
Post Posted: Fri May 06, 2011 7:35 am
Sidchrome NON impact sockets will not be covered under warranty if you use it on a rattel gun :wink:
Pearce-toff Racing
Post Posted: Sat May 07, 2011 6:49 am
okay, so this is what has happened. Ryobi 12 Volt Cordless impact driver, could eventually loosen the nut on the Cam Sprocket. Took a good 5 seconds thou.
What it could not do were the head bolts. Those hex shaped allan key type ones.
So I called in the another friend with a bigger gun. The tool brand was called Snap On and it was 18Volts.
With the exception of 2 bolts they all came out just fine. Those 2 would not budge no matter how long we had the tool on it. I was afraid the bolt will break.
With a 1meter breaker bar those last 2 bolts finally came undone.
Here are some pictures.
Post Posted: Sat May 07, 2011 6:50 am
forgot only allowed one image per post for some silly reason
Post Posted: Thu May 12, 2011 9:52 am
if anyone is interested on how the engine build is progressing, follow this thread
http://www.auszookers.com/index.php?nam ... ic&t=21731
Crank Balancing & engine building
Post Posted: Thu May 12, 2011 2:09 pm
Sometimes a little bit of heat from a propane will loosen them up enough to get them by hand.
Post Posted: Thu May 12, 2011 2:27 pm
uhmm... yeah.... just spray some propane on it lol.
I meant to say propane torch. :oops:
Users browsing this forum: Google [Bot] and 182 guests
