It is currently Sun Oct 11, 2026 1:34 am
Post Posted: Fri May 06, 2011 12:58 am
Anyone know where to get replacement seals for the free-wheeling hub assembly? Looks like a large o-ring but with square edges. Mine are perished and are letting water through.
Cheers Dan
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri May 06, 2011 1:01 am
Damo? did a write up on them a while back with where to get teh seals from I think
Post Posted: Fri May 06, 2011 7:50 am
I couldn't find the ones he's talking about.
Weaves?
Post Posted: Fri May 06, 2011 8:12 am
You should be able to take it into most bearing places and they will be able to find a quadring (square section o-ring) to match. Be pretty cheap, at work we have a $5 minimum if u want an invoice - iirc list price for quadrings would prob be less than $1 each lol
Post Posted: Fri May 06, 2011 8:17 am
Where bouts do you work mate?
Lil Foot!
Vehicle: LJ50V, SJ70
Post Posted: Fri May 06, 2011 8:21 am
Or almost any Japanese vehicle brand dealer.
Aisin hubs weren't just used on Suzukis, you'll find them on vehicles from Toyota, Isuzu, Daihatsu, Mazda and Holden. The inner and outer gaskets are the same too. The Aisin cap and body is the same across many models, it's just the spline count and shaft size in the inner dog that is different. All the springs, clips and seals will be the same as the hubs used on Suzukis.
I don't have a Suzuki dealership near me, so I go into the local Toyota/Holden dealership for hub gaskets. They have them in stock @ $1 for the outer cap gasket and $1.25 for the hub to FWH body gasket. I'm sure you could find the O-ring there too. I'll trip down there in the morning and get a price and part number.
Post Posted: Mon May 09, 2011 7:51 am
Well, that wasn't as cheap as I expected. The seal from Toyota is $6.85inc. Part number is 43582-60010. It may be cheaper as suggested to find a quadring from a bearing supply place.
Don't dismiss Toyota completely though. They list more individual components for the Aisin hub than Suzuki do, and it would be cheaper to replace a danaged clip or spring than to find a complete hub. The gaskets are cheaper than Suzuki.
Post Posted: Mon May 09, 2011 7:55 am
Thanks a heap for that 303!
Ill try and chase some down!
Lil Foot!
Users browsing this forum: No registered users and 306 guests
