It is currently Sat Oct 10, 2026 1:57 am
Post Posted: Fri May 06, 2011 7:45 am
I've managed to crack my first 1.3L transfer case :(
Any one got any good suggestions of local wreckers etc. that are worth asking?
I don't mind paying postage from over east but its not the best sized item to get posted; also if anyone knows a good postage company worth getting a quote off would be appreciated.
Post Posted: Fri May 06, 2011 7:49 am
8O I was looking for a w/t case for my jimny, didn't really look to hard, but anyway, i think the w/t cases are becoming rarer, your best bet would to try suzistore or suzukishop...
Vehicle: 4wd
Post Posted: Fri May 06, 2011 7:53 am
Was that with or without reduction gears?
Watch out or you'll get sued.
Post Posted: Fri May 06, 2011 7:59 am
Was during a 6.5 rebuild - long story short, I learnt the hard way
Cheers, I've tried them both... good guys, just a little pricey, might come down to getting 1 from over East just going to look local for a week
Post Posted: Fri May 06, 2011 8:07 am
will a 1L t/fercase fit? i'm sure there were some for sale, on Gumtree?
I HATE CYCLISTS!!!
What happened?
Post Posted: Fri May 06, 2011 8:08 am
SierraDan wrote:
What happened?
X2
I HATE CYCLISTS!!!
the one with the switch will.
Post Posted: Fri May 06, 2011 8:51 am
during the re build, all finished up 3 bolts to go and by the looks of it my mate tightened them too hard, because everything lined up
doesnt make too much sense, wish I was the 1 tightening them now to have known what pushed it over the edge
2 words - torque wrench
Vehicle: 2018 DMAX
Post Posted: Fri May 06, 2011 9:04 am
Wrong length bolts in those holes?? If the thread doesnt slip its just going to push on the case.
Post Posted: Fri May 06, 2011 9:26 am
goldy, read here: http://www.auszookers.com/index.php?nam ... cked+tcase
basically if the case is cracking you've either overtightened something or your mounts are too stiff transferring the load to the case. Either way it shouldnt ever crack the case.
oh yeah - and if you're running a roctoy ring, dont forget the holes arent all in line and flat like the ring is - you need some washers as spacers in some of the holes (hold the ring over the case and you'll see what i mean).
Post Posted: Fri May 06, 2011 10:52 am
Goldy i've got a 1lt case here in Perth with switch, i had it on here for sale a while ago and took it off because vl2dy4said he wanted to buy it but i have'nt heard from him for over 6 weeks so its yours if you want it $200 including f/r shafts and jack shaft.
Richo
97 Coily 2" susp lift 2" body lift + more
Post Posted: Fri May 06, 2011 11:01 am
Suzishop. I hear they are dodgy. I have used them for a Crank pulley and it works fine ;)
helloo
Vehicle: 4wd
Post Posted: Fri May 06, 2011 11:25 am
I thought they were both the same apart from the switch?
Post Posted: Fri May 06, 2011 12:55 pm
Richo
Mate i still want the case i can transfer the cash when ever. I sent you a few pms. Trying to gather some parts from Perth before i come up and get em in one hit? Sorry i havent contacted you sooner i read your last msg wrong :oops:
Conrad
0400 968 846
I HATE CYCLISTS!!!
Post Posted: Fri May 06, 2011 7:52 pm
I have a few empty 1.3 cases here if its just the case you want.
Post Posted: Sat May 07, 2011 10:47 am
Cheers for the replies
I'm going to slowly put the cracked case back together to see if I can find the cause, bolts, alignment or what not before I do the next 1 to avoid a repeat. Will update on where it went wrong.
P.S. I'm still looking for a Transfer Case, depending on how some of the pm replies go.
Post Posted: Sun May 08, 2011 5:34 am
Yeah....i definatelly agree that they are abit of a ripoff
I asked for a set of GTi seats and he wanted to charge....$300 EACH (not for the pair). I could get aftermarket seats for that brand new and he was like go for it....so i picked up a SET from here for $150 which were like brand new
In saying that, there aren't too many places that you can get Suzuki stuff here in WA so if/when you need something you're abit stuck for options
Post Posted: Sun May 08, 2011 6:05 am
http://www.4x4wreckers.com.au/ this joint has a sierra there wrecking. not sure what there like but i think there was a pic of it on the website
THINKING BEFORE POSTING!!!
Post Posted: Sun May 08, 2011 7:32 am
yeah thats the place i was saying "landsdale 4x4" ... theyre not bad, still a bit pricey and i didnt find them very negotiable on price of wrecked bits at the time.
Users browsing this forum: No registered users and 213 guests
