Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Sat May 07, 2011 10:54 am |
okay, finally aquired enough parts to make some headway with my lwb
and will be fitting a nissan engine. I have to fab engine and box mounts as well as move the transfer 120mm back, fit hydraulic clutch and move the handbrake also.
My question to those of you that have undertaken such an involved project before is should i take the body of to do the majority of the work or battle away with it on. I was thinking of getting the donk sitting in the engine bay roughly where i want it, marking the most rearward point of the engine in relation to the firewall on the chassis then take body of and start with the engine and box fitment.
I realise the body will have to be on for some stuff i just think i can do the big stuff faster and better with the bod off.
what do ya reckon ?
_________________ ...
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sat May 07, 2011 10:56 am |
You should be able to get everything right the first time in terms of clearances with the body on.
_________________ mlm
MrRocky
 Posted: Sat May 07, 2011 11:02 am |
yeah i know that, just thinking about grinding the transfer mounts, crossmembers and so on... of the chassis. Not alot of room there with the body on and i'd like to do it neat.
smiffkid
Joined: Fri Aug 13, 2010 12:55 pm Posts: 3266 Location: perth wa
 Posted: Sat May 07, 2011 11:51 am |
get it set up then take body off, gives room to move, then finishing touches with body on,
considering all the wiring is goona be exchanged
_________________ dodgy brothers mechanical
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Sat May 07, 2011 12:39 pm |
Body off. I have done the same mods on my ute and it was so much easier with the cab off.
_________________ 2013 GV 1998 SV420 ute
Gwagensteve
 Posted: Sat May 07, 2011 10:41 pm |
Cab off.
It takes a few hours, but that's more than made up in every other job being easier to do, and easier to do properly- for example, welding the gearbox crossmember in, or aligning the gearbox and transfer.
In fact, I'd even pull the axles so you have a bare chassis, then all your welding can be done "in position" - no need to weld anything upside down, for instance.
Makes for a much higher standard of build.
MrRocky
 Posted: Sat May 07, 2011 10:52 pm |
thanks guys that confirms my thoughts off it comes
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 192 guests
