It is currently Thu Oct 08, 2026 1:19 am
Post Posted: Mon May 09, 2011 11:36 pm
I just bought a G16B from a damaged Baleno, what extra parts from Car are required for the transplant to Sierra/Maruti,also does anyone Make or have a design for the Water outlet at rear of Motor.
Thanks
Post Posted: Tue May 10, 2011 12:00 am
Read here:
http://www.auszookers.com/index.php?nam ... 23&start=0
And here, because your engine mounts will be suited for a 1L(going by your username)
http://www.auszookers.com/index.php?nam ... 99&start=0
And here:
http://www.outerlimits4x4.com/viewtopic ... lit=Baleno
Post Posted: Tue May 10, 2011 12:41 am
I already have G13ba fitted with 1.3 mounts and a Bent adapter,just got to remove all required parts from Baleno wreck this weekend.
Post Posted: Tue May 10, 2011 12:55 am
Really just need the motor and all wiring(including the cluster if you want a stockish tacho if coilpack model)
Twin coil or dizzy?
Post Posted: Tue May 10, 2011 1:00 am
If you already have 1.3 mounts it's pretty strait forward, just need motor, loom, cluster.
You will need a thermostat housing from an early swift, it's right angle.
You will need the 1.3 sump and pickup, you have to cut the piece from the bal sump where crank sensor is and weld to your sierra sump.
Should also get vl commodore rb30 engine mounts as these are way stronger.
Probably more but that's all I can think of the top of my head.
Good luck.
My Maruti build, Click WWW
Post Posted: Tue May 10, 2011 1:03 am
Good luck.
check the links.. :lol:
Vehicle: 1987 sierra tray back buggy
Post Posted: Tue May 10, 2011 1:07 am
Take everything that dosent take up much room. Then ditch the body. You will be surprised at the usefulness of the parts.
Post Posted: Tue May 10, 2011 1:28 am
Thanks all
Its the coil pack version [No Dizzy] and its up the Central Coast NSW,just making sure I dont leave anything behind that might be required.Been reading the 16B post just double checking.
Post Posted: Tue May 10, 2011 2:27 am
http://i161.photobucket.com/albums/t218 ... omrear.jpg
is that what u need made up?
im after one too
Post Posted: Tue May 10, 2011 2:48 am
Some people are able to use the stocko one with a swift housing on it.
I wasnt able to as my engine was closer to the firewall, and good luck changing the thermostat..
There is many threads on this already.
I have to make one again for my new one.
Should i make 3.. :lol:
Post Posted: Tue May 10, 2011 5:47 am
hey mate if you could get one made up for me that would be awesome. when are you thinking about doing it?
i havnt fitted my engine yet, im waiting to get my sump welded by fatzook. everything else is ready to go.
im pretty sure that i need something like that made up because i have 2inch bodylift and im using VL engine mounts
Post Posted: Tue May 10, 2011 9:33 am
If you got time to make extra fitting I am interested,PM price
The motor I picking up is from 2000 Baleno manual
Post Posted: Wed May 11, 2011 3:47 am
Thanks alot!!!!!!!!
I was bidding on that! Pipped me on the last second.
Mitch.
Post Posted: Wed May 11, 2011 6:17 am
I'll pick the motor up from lake munmorah and install it for you
In my car :lol:
F#%ING [P] PLATER
 Profile YIM
Users browsing this forum: No registered users and 291 guests
