It is currently Tue Oct 06, 2026 1:07 pm
Post Posted: Thu May 12, 2011 12:03 am
Hi, :helloo:
New to the site, and new to Vitara's. In fact so new I ain't got one--yet! I'm about 4 weeks off picking up one, just gotta sell my fuel guzzling Jeep first.
The plan is to buy a stock mid 90's JLX and slowly put a few $$ into doing it up. Not going too over board (yes I know, very boring :roll: ), probably just put some bigger MT tyres on it and lift the body 50 mm. So can anyone tell me if I can put a set of 235/75's on the standard 15" rims? I'm planning to run a set of Kuhmo MT 834 as the reviews all seem pretty good a an all-round tyre. If they're crap, just tell me :D
Also can anyone recomend a good kit to lift the body 50mm? Just want a bit more clearence and hopefully help with running the bigger tyres mentioned.
If you want 94 Jeep Cherokee that uses slightly less fuel than a Sherman tank, just let me know... :lol:
Cheers,
Phil
Vehicle: '96 LWB trayback
Post Posted: Thu May 12, 2011 12:55 am
That tyre size will be fine on the stock rims. Some tyre shops will tell you that you need a 6" width minimum, tell them to HTFU and fit them.
Post Posted: Thu May 12, 2011 12:57 am
50mm body lift.
http://www.auszookers.com/index.php?nam ... ic&t=15518
Post Posted: Thu May 12, 2011 1:20 am
body lifts are available here: http://www.auszookers.com/index.php?nam ... ic&t=15518
i would recommend doing a spring lift first (better ride, better offroad, better clearance etc) and then doing a BL (body lift) or coil spacers later on if you still need more height.
Post Posted: Thu May 12, 2011 1:55 am
i would recommend doing a spring lift first (better ride, better offroad, better clearance etc) and then doing a BL (body lift) or coil spacers later on if you still need more height.[/quote]
Thanks for replys.
Alex, you mentioned spring lift first, can you recomment any kits for a Vitara?
Cheers,
Phil
Post Posted: Thu May 12, 2011 2:05 am
theres a few different brand that do a kit around 30-40mm lift: ironman, Tough Dog, king springs. i cant recommend any of these coz i haven't used any of the kits before. there are around $800 and arepretty easy to install to if you mechanically minded.
Post Posted: Thu May 12, 2011 2:06 am
Kings springs and Koni shocks. :wink: About $1500 fitted. 40mm lift.
Post Posted: Thu May 12, 2011 4:49 am
Cool. Thanks guys, I'll look at the option and see which best suits my budget.
Cheers,
Phil
Post Posted: Thu May 12, 2011 4:54 am
If your gonna spend that much go the Calmini 3" lift. Whole kit with all the trick bits you'll need down the track anyway.
BTW there is no such thing as not going overboard. Once you start tricking it up there aint no end to it....ask my missus.
Post Posted: Thu May 12, 2011 4:57 am
Even though most people throw the shocks, struts and coils in the bin :roll: Great value :crazy:
Vehicle: SJ51T
Post Posted: Thu May 12, 2011 5:03 am
Exact reason i never bothered. The extra inch of lift isnt worth it.
I went lifted king springs. Commodore rears, and ive still only done a strut mount flip on the front. My struts are still in good nick so im not willing to pay $300 for struts that will give me an extra 20mm of extra travel or whatever it is.
Vehicle: LWB Sierra & XL7
Post Posted: Thu May 12, 2011 9:15 am
matty_wall wrote:
The extra inch isnt worth it.
You might wanna ask a chick about that ;)
How wild or mild you make it depends on the type of terrain you will mainly drive, a good and easy start is like any 4WD, 2" lift and the 75 series tyres will fit easily.
As for what combo springs and shocks you get, well your a little spoilt for choice, but check out Dobinsons shocks. After putting them in mine, I'd definitly put them in any other 4B I'd get. They also do springs.
Users browsing this forum: Google [Bot] and 102 guests
