It is currently Wed Oct 07, 2026 9:19 pm
Post Posted: Wed May 11, 2011 1:27 am
97 sierra jx, needs a rebuild our a new engine. What's the best option? Working on a budget. Can a leafy engine fit in?
Vehicle: 03 Jimny
Post Posted: Wed May 11, 2011 1:33 am
Both wt leafy and coily are g13ba
Post Posted: Wed May 11, 2011 2:52 am
Find a 1.6 vitara carb block if your not after anything hard and use same wiring. All you will need then is a adaptor plate and a few other various mods. (search alittle you will find)
Will give you more powa!
Otherwise, Just rebuild the one you have?
Post Posted: Wed May 11, 2011 6:19 am
[quote="BlueSuzy"]Find a 1.6 vitara carb block if your not after anything hard and use same wiring. All you will need then is a adaptor plate and a few other various mods. (search alittle you will find)
So does this mean my head (G13ba) will bolt on to a 1.6 block??
97 Coily 2" susp lift 2" body lift + more
Vehicle: 03 Jimny
Post Posted: Wed May 11, 2011 6:30 am
Yes it will
That's what I have
Post Posted: Wed May 11, 2011 11:17 am
so what other mods are required apart from adapter kit??
Users browsing this forum: Google [Bot] and 215 guests
