It is currently Mon Sep 21, 2026 2:10 pm
Post Posted: Thu May 12, 2011 3:19 pm
Hi guys it probably has been discussed before, i was wondering if the RockyRoad RUF kit was any good instead of doing a chassis extension.
it will cost me $75+$100USD delivery, if anyone makes these bolt on kits in Australia please let me know.
I might even try and make some myself surely it cant be that hard!
Here is a link http://www.rocky-road.com/ruf.html
If anyone has used this bolt on kit before please let me know.
I will be running OME rears up Front.
Sorry bout another RUF thread.
I HATE CYCLISTS!!!
Post Posted: Thu May 12, 2011 3:53 pm
check out Moph's build he did something similar but DYI & his seems to work well off road,
http://auszookers.com/index.php?name=Fo ... ic&t=10046
Vehicle: 93 Sierra
Post Posted: Thu May 12, 2011 5:16 pm
Rockyroad don't use enough bolts but! :P
Seems pretty strong the way I've done it. I haven't jumped it, but it has done a few hundred kays of fast hard corrugations with some big bumpstop slapping bottom outs at 100kph without any dramas.
Post Posted: Thu May 12, 2011 6:58 pm
Rocky Road can be unreliable with waiting times..
This kit puts diff in original location.(unsure if you are after that or not)
Post Posted: Thu May 12, 2011 8:17 pm
id just make them my self...
but as bluesuzy said, it puts your diff in the std position?!?! is that what you want??
Post Posted: Thu May 12, 2011 8:26 pm
I have seen this kit twice, 1 spoa, 1 spua. Both worked fine with 31's. But larger, you will get firewall clearance drama's.
It actually moves your diff back and you have to redrill your diff forward to get the stock position back. So moving it another 25mm forward for firewall clearance is out of the question.
Next option is cutting the firewall/floor.
Easy to make yourself also. But bolt-on, i wouldnt be happy with it.
Vehicle: 91 WT 1.6EFI
Post Posted: Thu May 12, 2011 9:34 pm
might as well flip and weld. I think alex had something in his build up thread. easy to do and will look like it belongs if its done well.
Post Posted: Fri May 13, 2011 1:19 am
Take a look at the "YJ relocation plates", or "RUF relocation plate diagram" the yank forums. If you don't want to hit the yank forums, google will give you a good drawing with measurements.
Cut them out, then stack them together and drill. This is one time DIY is just as good, and less expensive.
I know trail tough is more expensive, but their parts rock for RUF, and YJ. You get what you pay for rings true with these guys, they make some seriously sturdy, safe parts.
Post Posted: Fri May 13, 2011 1:26 am
Post Posted: Fri May 13, 2011 2:08 am
Maybe Mr. Fatzook can produce something similar (but better ;) ) for the Aussie market?
I want my old sig back :(
Post Posted: Fri May 13, 2011 2:17 am
Awesome idea.
TSOR to the rescue armsup
Post Posted: Fri May 13, 2011 8:47 am
What do you guys reckon about this diagram for RUF relocation plates? Would they work well?
I HATE CYCLISTS!!!
Post Posted: Fri May 13, 2011 12:24 pm
no good vl2dy4 measurements are imperial, suzukis are metric. :crazy:
:helloo:
Post Posted: Fri May 13, 2011 8:42 pm
Don't matter measurements still work
Post Posted: Fri May 13, 2011 9:06 pm
That'd just be bolt sizes thouh wouldn't it?
Post Posted: Fri May 13, 2011 11:08 pm
Yeah it is disapointing to me how this has got around, it is a method that I have been using since around 1990, because of how it is done it is not easily recognised as being any difference from original. When he was seeking info about how people do their RUF's (and getting some bad advice) I told him about this method and gave him the measurements I actually asked him not to spread it around because I wanted it to remain fairly stealth. He chose to ignore that request and posted pics of it on an open forum for all to see, which is why I am now reluctant to share that kind of information. The more widely spread it is the less stealth it becomes. I know traffic coppers and qld transport inspectors trawl the forums building on their knowledge to help them on the job, pictures spell a thousand words and when you start saying "the cops won't even know when you do it this way" it is just challenging them to have a good look under the front of every Suzuki they pull over.
Post Posted: Fri May 13, 2011 11:37 pm
the problem is the different length of rear springs that people will use. So every kit needs to be made to each spring. The only way he will do them is if he supplies the springs, that way the shackle angle will be right and people won't think he made a shit product.
My Rig --> Click WWW
Users browsing this forum: No registered users and 132 guests
