It is currently Sat Sep 19, 2026 5:33 am
Post Posted: Sat May 14, 2011 12:19 am
I have some 1.3 n/t diffs would the carriers and centers fit my w/t diffs thinking of keeping the centers and selling of the axles
jimbo
 Profile YIM
Vehicle: 03 Jimny
Post Posted: Sat May 14, 2011 12:56 am
The centers should be 3.9 ratio
I just put nt 1.3 centers in my wt diffs
Post Posted: Sat May 14, 2011 12:59 am
Yes they will fit in the WT diffs, but as zooky08 said they are a different ratio to WT so they have to be put in as a pair.
Post Posted: Sat May 14, 2011 2:52 am
cool thanks and yeah I have the matching pair
 Profile YIM
Post Posted: Sat May 14, 2011 9:12 am
by this talk, i assume NT has a lower ratio? (better for crawling?)
or is it that much of a small difference its not worth the hassle?
Vehicle: 03 Jimny
Post Posted: Sat May 14, 2011 9:29 am
Nt centers won't fit a wt housing
Only nt 1.3 centers fit in a wt housing
Not sure if there's a big difference between 3.7 and 3.9 ratios
But crown and pinion gears aren't like transfer gears
Post Posted: Sat May 14, 2011 9:31 am
N/t 1lt center's......
& :blink:
changing diff gears is a better way of addressing larger tyres though, as it puts less strain on the tcase. changing from 3.7 to 3.9 is a 5.4% difference, so would bring your 215/75r15 tyres back to factory gearing.
Post Posted: Sat May 14, 2011 9:34 am
& :blink:
Should of added more...
The Lt N/t are lt, won't fit 1.3, but 1.3 w/t to n/t fit ( 1.3)
& IF A REDUCTION OF GEARING IS MADE, NO MATTER HOW SMALL, YOU ( fucking cap's lock) are at an advantage.....
Vehicle: 03 Jimny
Post Posted: Sat May 14, 2011 9:43 am
Ahk ok thanks
What's the ratio % of a tyre size of 30inch
Ill be having 3.9 diff ratios with 4.16 transfercase gears for my 30's and I'm not sure if thats going to work well
Post Posted: Sat May 14, 2011 10:16 am
30s are around 15% larger... 4.16tcase gives 12% high range doesnt it? add the 5% in diff reduction and you're onto a winner i reckon.
Post Posted: Sat May 14, 2011 10:20 am
4.1's give a 1.3L a 12% reducion in high. But 0% reduction for a 1L, as the high range ratios are the same.
Vehicle: 03 Jimny
Post Posted: Sat May 14, 2011 10:23 am
I have a 1.6l :wink: :?
Post Posted: Sat May 14, 2011 10:32 am
So? You have a 1.3L transfer? Then 4.1's will give a 12% reduction.
If you had a 1.6L with a 1L case, then fitted 4.1's you would get no change in high range.
A B C D E F .......... :roll:
:thefinger:
Vehicle: 03 Jimny
Post Posted: Sat May 14, 2011 10:39 am
Yea I will have a 1.3 case fitted with LWOR 4.1 gears
3.9 diff gear, 30's and running a g16a engine
Users browsing this forum: No registered users and 157 guests
