It is currently Sat Sep 19, 2026 6:23 am
Post Posted: Sat May 14, 2011 7:41 am
Just wondering what sort of grease to use on front hubs?
Post Posted: Sat May 14, 2011 7:48 am
i used high temp grease, but i think you can also use Molybdenum Disulfide. Also make sure you use gasket goo on all the parts the service manual recommend (e.g. swival hubs, king pin, the gap between the two swival outer plates, part of swival seal... )
Post Posted: Sat May 14, 2011 8:08 am
It's the black/grey colored grease you want for the cv's and a wheel bearing grease for the wheel bearings
Post Posted: Sat May 14, 2011 8:58 am
The problem i got is the free wheeling hubs are getting hard to move from free too lock i serviced them about twelve months ago and were good for a while but dont know if i used the right grease?
Post Posted: Sat May 14, 2011 9:23 am
I used high temp bearing grease on my fw hubs about 18 months ago and they are still working fine, not to sure if thats the right grease to use though
Post Posted: Sat May 14, 2011 9:36 am
Did you strip them completely apart? I find some of them get tight where the o-ring seals the turning part
Users browsing this forum: No registered users and 177 guests
