It is currently Tue Sep 22, 2026 3:05 am
Post Posted: Mon May 16, 2011 11:12 am
I have a placard on the side of my ute saying 16 6.00
As far as I can find using google they were an early tractor tyer.
I think they were on the 1L utes??
But what size do they measure now days??
I cant get a conversion via google and Ive searched on AZ but it keeps saying no topics ,etc.
Post Posted: Mon May 16, 2011 11:14 am
try this. Very usefull.
http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx
Post Posted: Mon May 16, 2011 11:15 am
6.0 x 16
Results for your selected Wheel/Tyre
Metric Equivalent 150 / 100 R 16
Rolling Radius 353.2mm
Circumference 2219.22mm
Diameter 706.4mm
Post Posted: Mon May 16, 2011 11:22 am
Thanks mate
So from what I can figure using that they would be about 28's??
I thought I had read somewhere that they were about 31's??
Vehicle: LJ50V, SJ70
Post Posted: Mon May 16, 2011 12:46 pm
remydog05 wrote:
Thanks mate
From THIS thread, 6.00-16=725mm=28.1in.
Post Posted: Mon May 16, 2011 9:14 pm
That doesn't add up...
6.00-16 is 6inch sidewall times two plus 16 inch rim equals 28 inch OD.
28 X 25.4 = 711.2mm
Post Posted: Mon May 16, 2011 10:59 pm
I've got two (half worn) 6.00 16s, they measure 27.5 inches tall, 6 inches wide.
The 7.50 16s I now run are right on 32 inches tall.
Post Posted: Mon May 16, 2011 11:24 pm
28 X 25.4 = 711.2mm
Correct!
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed May 18, 2011 3:15 am
28 X 25.4 = 711.2mm
6.00-16 is a nominal tyre size, not an accurate carcass dimension, so a simple calculation of rim plus 2 sidewalls is rarely correct. But you're right, 725mm does not equal 28.1in! My whoops. :oops:
There are 2 tyre brands that currently sell 6.00-16 bar treads in Australia that I know of. Both are Indian. MRF lists their NDMS on page 27 and gives the diameter as 735mm, or nearly 29 inches! Deestone list their D501 in a brochure I have, and gives the diameter as 723mm.
An American brand of tyres, STA list theirs as 28.6in or approx 724mm.
A nominal tyre size is indicative only and should never be relied on to give an accurate size. I once had two 7.50-16 tyres on an old ex-army Landrover that were over 1 1/2 inches different in overall dia despite both being 7.50-16s! One was an Olympic and the other a Hardie, both made in Australia. You should never mix brands of tyre and where possible production dates as tyre specifications will change by brand and lot number!
Users browsing this forum: No registered users and 187 guests
