It is currently Mon Sep 21, 2026 5:58 am
Post Posted: Mon May 16, 2011 10:33 pm
hey guys i was just wondering if a 92 barina engine would bolt straight in to my sierra i have heard they do but just want to be sure.
Vehicle: lj81 stockman
Post Posted: Mon May 16, 2011 11:07 pm
it will have to change the carby but
the wobble rocks
Post Posted: Mon May 16, 2011 11:09 pm
okay thanks for that just wanted to make sure and im about to get my carby rebuilt anyway so that will work out thanks for that.
Post Posted: Mon May 16, 2011 11:20 pm
Might have to swap the sump, oil pick up and mounts to.
Post Posted: Mon May 16, 2011 11:40 pm
okay well i will just check it all i when i put it in and then i will go from there my main worry was just if it lined up with the box
Post Posted: Tue May 17, 2011 12:07 am
Same block bud, no worries bout lining up with the gearbox
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Tue May 17, 2011 12:09 am
I believe the distributor will also need to be replaced.
Post Posted: Tue May 17, 2011 12:14 am
okay good would the dizzy just be a straight swap.
Post Posted: Tue May 17, 2011 12:29 am
as per: http://www.auszookers.com/index.php?nam ... ic&t=20699
The cam needs to be changed to put the sierra distributor on. You will also have to change alternator or alternator pulley, inlet manifold, fuel pump, water pump or put a thermo fan on, crank pulley if you change water pump.
Post Posted: Tue May 17, 2011 1:00 am
Well i have the 110 ford alt so thats not a problem a already run a thermo ill change manifold when carby is finished so that just leaves the camshaft and how hard is that to change
Post Posted: Tue May 17, 2011 1:08 am
its easy, just remember to remove fuel pump first and remove the pin which is driven off the cam shaft.
If you forget to remove this pin, you will have a hard time removing the camshaft and end up damaging the head.
Post Posted: Tue May 17, 2011 1:10 am
okay well i will get a manual just to be sure thanks for the help guys greatly appreciated.
Users browsing this forum: No registered users and 145 guests
