http://auszookers.com/forum/
92 barina engine
http://auszookers.com/forum/viewtopic.php?f=5&t=22013
Author:  stewy91 [ Mon May 16, 2011 10:33 pm ]
Post subject:  92 barina engine
hey guys i was just wondering if a 92 barina engine would bolt straight in to my sierra i have heard they do but just want to be sure.
Author:  gypsy [ Mon May 16, 2011 11:07 pm ]
Post subject:  Re: 92 barina engine
it will have to change the carby but
Author:  stewy91 [ Mon May 16, 2011 11:09 pm ]
okay thanks for that just wanted to make sure and im about to get my carby rebuilt anyway so that will work out thanks for that.
Author:  zuk_244 [ Mon May 16, 2011 11:20 pm ]
Might have to swap the sump, oil pick up and mounts to.
Author:  stewy91 [ Mon May 16, 2011 11:40 pm ]
okay well i will just check it all i when i put it in and then i will go from there my main worry was just if it lined up with the box
Author:  Kermy87 [ Tue May 17, 2011 12:07 am ]
Same block bud, no worries bout lining up with the gearbox
Author:  fordem [ Tue May 17, 2011 12:09 am ]
I believe the distributor will also need to be replaced.
Author:  stewy91 [ Tue May 17, 2011 12:14 am ]
okay good would the dizzy just be a straight swap.
Author:  Zook_Fan [ Tue May 17, 2011 12:29 am ]
as per: http://www.auszookers.com/index.php?nam ... ic&t=20699
The cam needs to be changed to put the sierra distributor on. You will also have to change alternator or alternator pulley, inlet manifold, fuel pump, water pump or put a thermo fan on, crank pulley if you change water pump.
Author:  stewy91 [ Tue May 17, 2011 1:00 am ]
Well i have the 110 ford alt so thats not a problem a already run a thermo ill change manifold when carby is finished so that just leaves the camshaft and how hard is that to change
Author:  jdk81 [ Tue May 17, 2011 1:08 am ]
its easy, just remember to remove fuel pump first and remove the pin which is driven off the cam shaft.
If you forget to remove this pin, you will have a hard time removing the camshaft and end up damaging the head.
Author:  stewy91 [ Tue May 17, 2011 1:10 am ]
okay well i will get a manual just to be sure thanks for the help guys greatly appreciated.
