It is currently Mon Sep 21, 2026 2:03 pm
Post Posted: Tue May 17, 2011 2:28 am
I have a G16b in the Maruti which was removered [I didn't remove) from a already running converted Maruti.I need to Verify a few wires which were not marked
1.Yellow black trace (A9)
2.White (A1)-I beleive Tail Light +
3.Couple Black-wires I beleive are Earth
Also which connection is to activate starter solenoid as I have traced to A2 socket on ECM,all do I just join (solder) with old wire circuit
Post Posted: Tue May 17, 2011 2:30 am
Black wires are Black just look Blue in Photo strange
Post Posted: Tue May 17, 2011 2:38 am
Black with blue trace is Sensor Earth
Yellow and black is VSS? I think, not sure
White might be ECU battery power
starter should be black with yellow trace, which hooks to black with yellow trace in teh sierra loom :)
This is all based on g13bb being the same colours and my memory being correct
Post Posted: Tue May 17, 2011 5:29 am
Starter is same as I track it to ecm,is their a input connection on ecm or do I connect original start wire between starter
& ecm
Post Posted: Tue May 17, 2011 5:34 am
yeah starter is jsut an input, connect it off the original start wire
Post Posted: Tue May 17, 2011 6:44 am
& ecm
You have a pm
F#%ING [P] PLATER
 Profile YIM
Users browsing this forum: Google [Bot] and 128 guests
