| HELP!!! http://auszookers.com/forum/viewtopic.php?f=5&t=22018 |
| Author: | zukmeista [ Tue May 17, 2011 2:46 am ] |
| Post subject: | HELP!!! |
[img][IMG]http://img580.imageshack.us/img580/4223/mudzuk031.jpg[/img][/img]Not only have I got a screw loose, my motor has two loose, so loose that they have run away [img][IMG]http://img543.imageshack.us/img543/6779/mudzuk030.jpg[/img][/img] [img][IMG]http://img863.imageshack.us/img863/2711/mudzuk029.jpg[/img][/img] [img][IMG]http://img189.imageshack.us/img189/1158/mudzuk032.jpg[/img][/img] |
| Author: | gypsy [ Tue May 17, 2011 2:47 am ] |
| Post subject: | Re: HELP!!! |
sump |
| Author: | SuziBlu [ Tue May 17, 2011 2:55 am ] |
Dunno where they have gone, but its a pretty normal thing to see once the rocker cover is lifted, a screw loose in a sierra is normal. er, a 1.3l that is. |
| Author: | zukmeista [ Tue May 17, 2011 2:57 am ] |
Yeah, I have heard of this, so thought i'd check |
| Author: | SuziBlu [ Tue May 17, 2011 3:02 am ] |
Found mine up top, was pretty hidden. |
| Author: | stewy91 [ Tue May 17, 2011 3:05 am ] |
i had one jammed in the corner where the oil goes though its still there its stuck good |
| Author: | zookyute1981 [ Tue May 17, 2011 3:13 am ] |
now going to check mine |
| Author: | christover1 [ Tue May 17, 2011 7:41 am ] |
Use a very good lock tite product, it is a known problem. If engine still running, screws are hopefully somewhere safe |
| Author: | want33s [ Tue May 17, 2011 7:52 am ] |
I use loctite on them and then after fitting I use a centre punch to peen between the screw and the alloy it goes into.. The combination makes it impossible for them to come out. If you ever have to remove them, a good wack in the middle of the X with a small ball-pein hammer breaks the seal. |
| Author: | skyman [ Wed May 18, 2011 3:38 pm ] |
want33s wrote: I use loctite on them and then after fitting I use a centre punch to peen between the screw and the alloy it goes into..
The combination makes it impossible for them to come out. If you ever have to remove them, a good wack in the middle of the X with a small ball-pein hammer breaks the seal. excellent advice for a common problem, hope you find your screw! |
| Author: | zukmeista [ Wed May 18, 2011 7:02 pm ] |
Nah, just put two new ones in. |
| Author: | oozuk [ Wed May 18, 2011 8:09 pm ] |
Go hunting with a telescopic magnet in the top end and if no luck, sump off and go swimming around in there with the magnet |
| Author: | zukmeista [ Thu May 19, 2011 5:18 am ] |
Can't be bothered, it's still going |
| Author: | oozuk [ Thu May 19, 2011 5:31 am ] |
zukmeista wrote: Can't be bothered, it's still going
All the more reason to do it !! If the engine picks one up it will do damage, but with that attitude good luck mate. |
| Author: | zukmeista [ Thu May 19, 2011 5:34 am ] |
Could they damage the engine? Thought if they were in the sump that they would stay there? |
| Author: | MART [ Thu May 19, 2011 5:38 am ] |
This may not matter to you but oil will piss out those holes and not lubricate the rockers correctly , causing them to damage the camshaft and bearings , is it still piss funny , Cheers Paul. |
| Author: | SuziBlu [ Thu May 19, 2011 5:43 am ] |
What about if you tipped upside down, and could not get the engine off straight away, and it ran, screws went up, lock your engine solid, rotating mass tore threw the seizure, exploding the engine, sending shrapnell for miles, everyone dead, birds, n other things you have over there, maimed, and in terrible pain. You are found out to be the direct cause of this, coz one of the screws were found, and then a lynch mob came for ya. hmmm, don't say you havn't been warned. |
| Author: | Hybrid [ Thu May 19, 2011 5:49 am ] |
SuziBlu wrote: What about if you tipped upside down, and could not get the engine off straight away, and it ran, screws went up, lock your engine solid, rotating mass tore threw the seizure, exploding the engine, sending shrapnell for miles, everyone dead, birds, n other things you have over there, maimed, and in terrible pain.
You are found out to be the direct cause of this, coz one of the screws were found, and then a lynch mob came for ya. hmmm, don't say you havn't been warned. At least then that would take the spotlight of BP for the oil spill in the states. |
| Author: | SuziBlu [ Thu May 19, 2011 5:52 am ] |
ahh a, always look on the bright side of life. BP would be most greatful lol. |
| Author: | zukmeista [ Thu May 19, 2011 7:26 pm ] |
MART wrote: This may not matter to you but oil will piss out those holes and not lubricate the rockers correctly , causing them to damage the camshaft and bearings , is it still piss funny , Cheers Paul.
I put more screws in |
| Author: | 11_evl [ Thu May 19, 2011 7:35 pm ] |
drain your oil and use a flexy magnet up the drain plug and have a dig around |
