It is currently Sat Aug 01, 2026 8:32 am
Post Posted: Wed May 18, 2011 9:37 am
Hi
I took off my rear left wheel to spray the inner hub to find a leak
its like a greasy olive colour
would anybody know what would of caused this?
help will be appreciated.
the leak is shown on the bottom.
Uploaded with ImageShack.us
2004 Jimny
2" ome lift
15mm spacers
235 75's
Post Posted: Wed May 18, 2011 9:43 am
Axle seal :wink:
Post Posted: Wed May 18, 2011 9:47 am
should i not be driving the car at all?
2004 Jimny
2" ome lift
15mm spacers
235 75's
Post Posted: Wed May 18, 2011 10:11 am
Rusho wrote:
Axle seal :wink:
& wheel bearing, no point just doing the seal as the bearing's meant to have grease in it, not oil..
Post Posted: Wed May 18, 2011 10:12 am
get it done soon, or you diff will run out of oil & cost you more coin..
Post Posted: Wed May 18, 2011 10:13 am
that much coming out I wouldn't
is your brake fluid low?
Post Posted: Wed May 18, 2011 12:44 pm
I'm with Royce. Check brake fluid. I can smell a knackered wheel cylinder from here.... Or is that my dog?
Post Posted: Wed May 18, 2011 12:49 pm
I wouldn't be driving it.
helloo
Post Posted: Wed May 18, 2011 9:32 pm
Taste it. If it's bitter it's brake fluid. If it's got a rank smell it's diff oil
Post Posted: Thu May 19, 2011 7:39 am
thank you for the help everyone, i wont drive it till Monday when my mechanic looks at it :) hopefully it doesn't set me back much.
2004 Jimny
2" ome lift
15mm spacers
235 75's
Post Posted: Mon May 23, 2011 4:33 am
Turns out it was the axle seal, all fixed now :)
2004 Jimny
2" ome lift
15mm spacers
235 75's
Post Posted: Mon May 23, 2011 6:38 am
Cool
Post Posted: Mon May 23, 2011 7:51 am
:woohoo: I got something right :roll:
Post Posted: Mon May 23, 2011 8:16 am
Was bound to happen sooner or later :roll:
:thefinger:
Post Posted: Mon May 23, 2011 8:19 am
Was bound to happen sooner or later :roll: :thefinger:
:finger: :finger: :finger: :peaceout:
Users browsing this forum: Google [Bot] and 61 guests
