It is currently Sat Sep 26, 2026 4:18 am
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2  Next
Vehicle: 06 jimny, 1.8 SE
Post Posted: Fri May 20, 2011 3:19 am
Hi Guys and gals
Ive tried every tyre joint in town and they haven't had any luck getting me some decent looking alloys that will fit on the jimny
dose anyone here know of any that fit? :? im having no luck at all. :x
Thanks.
Post Posted: Fri May 20, 2011 3:41 am
I just had a quick check on the net, no idea of Jimny wheels stud placement, seems its the same as a vitara or sierra or f100.
So your choice is near limitless.
Post Posted: Fri May 20, 2011 3:44 am
i have two sets forsale at the moment mate,
there are atleast 2 other sets in the forsale thread.
it will all depend on what size and offset your after.
Post Posted: Fri May 20, 2011 3:47 am
Leaf sprung Sierra rims, particularly the Wide Track (WT) Sierras, have the same factory offset and stud pattern as Jimny so just tell them "To fit a Sierra".
EDIT: Will be a good guide but you'll still want to ensure the offset and width they come up with are compatible.
Post Posted: Fri May 20, 2011 3:50 am
aparently the stud pattern 5 X 139.7 :helloo:
and im interested to know this too, as in a future i would like to get some alloys too.... dnt mind the steel wheels, but i just want to have something different to everyone else
Post Posted: Fri May 20, 2011 3:59 am
I can find some 15x8 inch rims but i'm not to sure they will fit under ?
Post Posted: Fri May 20, 2011 4:05 am
from memory standard rims are 6inch, with a +5 offset.
if you go an inch bigger in width, you need to either go half an inch bigger in positive offset or start trying to cover tyres.
my 15 x 8s have approx -10 offset. so they are going to hang out a ways.
but i like offset soo... :)
Post Posted: Fri May 20, 2011 4:06 am
What size tyres do you want to run?
Post Posted: Fri May 20, 2011 4:07 am
235 75 15's and have 50mm lift if it helps
Post Posted: Fri May 20, 2011 4:09 am
I wouldn't go bigger than 7" with 235s as they'll roll off the rims at low pressure.
Post Posted: Fri May 20, 2011 4:11 am
i have another set that 15 x 7 with a good positive offset.
they need a really good polish. looking for $400
look like this
Post Posted: Fri May 20, 2011 4:13 am
Tanshi, So i would need to get 7inch with about + 20 off set
or 8 inch with about + 30 off set
Is that right
Post Posted: Fri May 20, 2011 4:15 am
thats the theory i believe.
but thats going to leave you with alot of wheel hanging inside the wheel arch, and it will probably foul on things.
7 inch is about as wide as i would go.
Post Posted: Fri May 20, 2011 4:16 am
[quote]I wouldn't go bigger than 7" with 235s as they'll roll off the rims at low pressure.[code]
OH ok, didnt know that
cheers.
Post Posted: Fri May 20, 2011 4:17 am
Want33 has a set for sale he told me last night at the bbq
Post Posted: Fri May 20, 2011 4:19 am
I dont mind these they are 15x 7 but i dont know about the offset or stud spacings on them.
Post Posted: Fri May 20, 2011 4:20 am
ew!! bbut any way :)
what brand and model are they?
Post Posted: Fri May 20, 2011 4:28 am
they are speedy. lol they look better on tyres.
Post Posted: Fri May 20, 2011 4:32 am
nope, by the looks they dont come in 5 stud
Post Posted: Fri May 20, 2011 4:35 am
I found here that a few people are running 15 x 7's on jimnys with neg 13 and neg 15 ?
that dosnt fit in with this
"Tanshi, So i would need to get 7inch with about + 20 off set
Is that right"
Post Posted: Fri May 20, 2011 4:38 am
http://en.wikipedia.org/wiki/Offset_(wheel)
Post Posted: Fri May 20, 2011 4:57 am
Pretty sure they're 5.5 wide.
Thanks for that :D
Just went and measured my spare.
Exactly 7" wide
Mounting face of the wheel is exactly centred in the 7"s. So no offset at all, hadn't expected that.
My XXalloysXX Mags :) fit the Jimny really nice, the tyres sit flush with the edge of the flare and there's plenty of room in the wheel wells and clearance from the arch lip for them to tuck inside. Close but clears.
I have no scrubbing issues although I'm on about 80'ish mm suspension lift. I think at 50mm a 235 on any rim will scrub. 60mm should work though.
Post Posted: Fri May 20, 2011 5:02 am
So it means that there is enough room to put wheels under the guards using 7 inch wide wheels with a negative off set?
Post Posted: Fri May 20, 2011 5:03 am
Thanks for that :D
Exactly 7" wide
So your saying your 15 x 7s are 0 mm offset? correct?
I suppose half an inch inward and outward isnt that much that it would hang out past the guards
Post Posted: Fri May 20, 2011 5:06 am
7inch rims with negative offset are going to hang out of the guards by the amount of negative offset going by Zukenutters info above
Post Posted: Fri May 20, 2011 5:09 am
Definitely
Thanks for that :D
Exactly 7" wide
YEP
Post Posted: Fri May 20, 2011 5:11 am
oh so im backwards lol
Post Posted: Fri May 20, 2011 5:14 am
yep, negative offset makes them stick out more.
so anything 0 offset in 7 inch will be fine. any thing positive offset will be fine.
Post Posted: Fri May 20, 2011 5:19 am
Will start getting very close to chassis. I totally fluked it with mine, anything either way will start contacting.
Post Posted: Fri May 20, 2011 5:21 am
ok then i take it back! buy an LJ :)
Users browsing this forum: Google [Bot] and 109 guests
