It is currently Tue Sep 29, 2026 7:24 am
Post Posted: Sun May 22, 2011 2:10 am
Has any one tried these?
http://www.lowrangeoffroad.com/index.ph ... rings.html
I am thinking of giving them a go and was wondering if anyone has had any experience with them.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Post Posted: Sun May 22, 2011 2:14 am
just buy cromo's.
Post Posted: Sun May 22, 2011 2:21 am
x2
Make your cv strong and the axle will go next.
What are you tyres running?
Post Posted: Sun May 22, 2011 2:27 am
Running 34in jungle treckers. Chromo's are alot more expensive and then i also have to get new side gears for my diff. These just press on.
Post Posted: Sun May 22, 2011 3:56 am
You will spend more time and money changing busted axles etc over time.
If your running 34's then you basically have to have chromos or your going to brake every time you drive.
Chromos are pretty cheap all things considered.
Vehicle: 03 Jimny
Post Posted: Sun May 22, 2011 4:09 am
$220 to my door for cromos
That's cheap I thought :blink:
Post Posted: Sun May 22, 2011 4:33 am
Were they from low range offroad?
Vehicle: 03 Jimny
Post Posted: Sun May 22, 2011 4:42 am
Yep sure was
Vehicle: 2018 DMAX
Post Posted: Sun May 22, 2011 4:52 am
Good price, mine were 300 before the doller turned good. For the price you cant say no.
Vehicle: 03 Jimny
Post Posted: Sun May 22, 2011 4:59 am
A good price I thought
I've still need the long shaft to come In the mail
I assume it would come all at once but it didn't :cry:
Post Posted: Sun May 22, 2011 5:14 am
but to answer your question they work like a treat.
the cv will be fine after the rings but then the problem will be breaking the axle.
having said that I ran rings on my cv's with the 34 swampers for atlest a year without axle issues.
but cromo's are the way to go
Post Posted: Sun May 22, 2011 7:12 am
just had a look at chromo's on on lowrange. To buy chromo's, and new side gears is gonna be about $370 plus about $140 postage = $510 (480AUS) or i can buy rings for 100 with 40 postage = 140 (130AUS). pretty big price difference. have also got a couple of spare axles now cause i only break the cv.
Post Posted: Sun May 22, 2011 7:21 am
Till you make it "stronger"
Post Posted: Sun May 22, 2011 7:22 am
I can't see the point of birfield rings. They just move the breakage point into something else that's too small - the 22 spline axle.
If you are super lucky and break the axle at the diff end, you might be able to get the axle out and replace it, but if you break the star in the centre of the CV (Typical if the CV goes with the wheel turned) then you've just wasted an axle, CV and birfield ring. It's false economy - you can't reuse the rings. One they're on, they're on.
Steve
Vehicle: 03 Jimny
Post Posted: Sun May 22, 2011 7:37 am
Cromos $135
Side gears $132(assuming you need two?)
85 postage(side gears will fit in the same box as the cromos
$352 total in us currency
Post Posted: Sun May 22, 2011 7:45 am
zooky08 wrote:
Cromos $135
Cromos are $235US ??
http://www.lowrangeoffroad.com/index.ph ... axles.html
http://www.trailtough.com/index.php?pag ... &Itemid=53
Vehicle: 2018 DMAX
Post Posted: Sun May 22, 2011 7:46 am
zooky08 wrote:
Cromos $135
You have a link to those cromos? That price doesnt look correct. I payed $235US for them
Vehicle: 03 Jimny
Post Posted: Sun May 22, 2011 7:47 am
Wow I just seen that
I got mine for 135 :)
I have the invoice right with me
Vehicle: 2018 DMAX
Post Posted: Sun May 22, 2011 7:48 am
But only one has turned up?
Vehicle: 03 Jimny
Post Posted: Sun May 22, 2011 7:52 am
Wait sorry the bloody invoices are all weird
I got three invoices
My bad $235 plus $85 postage
Not cheap now :(
Still be around $452 total
Yes only the 2 cv and short axel turned up
It's been a week nd the long one hasn't turned up
Sorry for the fulse info dominator
Users browsing this forum: No registered users and 171 guests
