Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
fire60
Joined: Sat Oct 16, 2010 2:02 am Posts: 96 Location: Wellington NZ
 Posted: Sun May 22, 2011 4:37 am |
I have picked up my next project from the car dump. It is a 95 5 dr Vit. 16v. I think it may have been burning a lot of oil, and the previous owner has over filled it by at least 2x more than normal. when we picked it up it was running but pretty rough though. Could this over filling have caused damage? if so what is likely?
Thanks in advance, Pete.
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Sun May 22, 2011 4:42 am |
2x's over full on the dipstick or does it have 9lt's in it??
rebuild it if it's using oil...
_________________ I used to be indecisive,
fire60
 Posted: Sun May 22, 2011 4:59 am |
I would think about 9 litres at least, it is way up the dip stick. The plan is to re build any way but I was curious as to what damage is likely as i have been told that over filling is not a good idea.
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
Vehicle: 03 Jimny
 Posted: Sun May 22, 2011 5:01 am |
If u say you got it from a car dump, make sure its not water in the oil to make it look like it's over full with oil, could be water in the sump as well
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Sun May 22, 2011 5:06 am |
Unless you drain the oil, its hard to say how much just by the dipstick.
The dipstick from empty to full is only a half litre or so, way up could be an extra litre.
Over filling will not damage the motor as such, it could be the cause of secondary issues, oil getting worked into a frothy state by the crank, and so not oiling properly.
Either way, rebuild.
_________________ Bad decisions make good stories.
steak_knife
 Posted: Sun May 22, 2011 5:07 am |
If it's run that far over full it can bend rod's..
drain it & see what's in there
fire60
 Posted: Sun May 22, 2011 5:08 am |
Will do thanks for that
Pete
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 147 guests
