It is currently Thu Oct 01, 2026 9:52 pm
Post Posted: Mon May 23, 2011 11:05 am
I made a dodgy 1-man bleeder tool and whilst it will suck fluid (from the reservoir and draw fluid to a head of about 2 feet) when I connect it to the bleed nipple I get a lot of air. I even tried using a hose clamp between the hose and the nipple. I think air is seeping past the thread of the bleed nipple.
I then went back to a 2-person bleed and there was no air in the fluid.
I had thought about buying a mityvac vacuum bleeder but if air is getting past the thread will the mityvac experience the same problem?
Is there any way of sealing the thread? I don't really want to use thread tape though.
Yes it looks dodge but it seems to work at sucking...
2002 SWB GV
Lifted and Locked
Vehicle: Daisy
Post Posted: Mon May 23, 2011 11:12 am
Maybe fab up something to seal around the whole nipple, like a balloon or something?
Post Posted: Mon May 23, 2011 11:13 am
get some small fuel line to slip over the nipple and put a little bit of metal pipe in the plastic and fuel line. no more air leaks.
Post Posted: Mon May 23, 2011 11:21 am
yeah nipple threads arent meant to be sealed
ive always bled brakes by myself, tube on the nipple, other end in a bottle that already has some fluid in it, pump for a bit then let it sit a bit to syphon some and do the bleed up
apparently its common for bike shops when bleeding brakes to drain it then the pump fluid in via the nipple so the system fills from the bottom up, there are machines to do it and all
Post Posted: Mon May 23, 2011 11:35 am
So how do vacuum bleeders work? How do they seal?
2002 SWB GV
Lifted and Locked
Post Posted: Mon May 23, 2011 11:37 am
simple, they don't work :) you just keep sucking till you get sick of it and assume its ok or you throw the thing in the bin
Post Posted: Mon May 23, 2011 11:48 am
Apparently its common for bike shops when bleeding brakes to drain it then the pump fluid in via the nipple so the system fills from the bottom up, there are machines to do it and all
Shimano, Hayes, and Magura MTB brakes can all be bled like this
Post Posted: Mon May 23, 2011 12:08 pm
yep that how taughttought 10 years ago when I apprentice
 Profile YIM
Post Posted: Mon May 23, 2011 3:04 pm
So with the jar and one man way of doing it, does the jar and hose need to be above the nipple, or can you just sit it on the ground as long as the hose is covered enough to suck fluid?
Post Posted: Mon May 23, 2011 8:13 pm
on the ground, but you need enough fluid in the jar to stop it sucking air back in.
Post Posted: Mon May 23, 2011 8:45 pm
x2 works really well
Post Posted: Tue May 24, 2011 1:11 am
Thanks guys I will give this ago. It sure beats the pump the pedal, crack the bleeder, hit the floor, close bleeder, repeat a thousand times method. :mrgreen:
Post Posted: Wed May 25, 2011 7:53 am
Yeah Royces method is the way to go, I have always done it that way and have only had one vehicle that gave me grief. It was an RX2 rally car, it had inline hydrolic hand brake and rear discs off something else. After playing with it for a day trying to get a firm peddle the previous owner came around and showed me how to do it, he had a spare master cylinder cap with a tyre valve fitted to it, he filled the master cylinder, hooked up an air line set at a very low pressure and pressure bled the fluid through.
Post Posted: Wed May 25, 2011 7:59 am
Has anyone tried these.
Post Posted: Wed May 25, 2011 8:02 am
I haven't because they are not an off the shelf part here, but everyone I know who has them raves about them.
They crack the bleed, pump a few times, and they are done. I really want a set of those badly.
Post Posted: Wed May 25, 2011 10:12 am
I've thought about this as well...but with a difference. I was going to keep my factory bleed nipple and use a short piece of clear tube (that I use for bleeding) connected to the screw thread part of the Speedbleeder. The tube can then be connected to the factory bleeder and bled like normal. Does this make sense? Do you think it will work?
2002 SWB GV
Lifted and Locked
Post Posted: Wed May 25, 2011 10:38 am
It will work, there's a guy on one of the US boards that did that, because he didn't want to have to buy four, He just uses one speed bleeder for all the cylinders.
Users browsing this forum: Google [Bot] and 181 guests
