It is currently Tue Oct 06, 2026 8:53 pm
Post Posted: Tue May 24, 2011 12:21 am
Just wondering how to tell the difference between a nt and a wt diff housing as I have been given some housings but am not sure Wat they are cheer
Post Posted: Tue May 24, 2011 12:28 am
Nt would have a smaller width than a WT. And the perch spacings on an nt would be smaller than a WT.
Vehicle: 03 Jimny
Post Posted: Tue May 24, 2011 12:41 am
What sierradan said or Driver side perch in the front will be up on the pumpkin a bit
Post Posted: Tue May 24, 2011 1:29 am
Telling someone the perch is on the diffs closer than the other isnt helping anyone.
http://www.auszookers.com/index.php?nam ... pic&t=7678
This is the measurements, between wheel mounting surfaces.
Post Posted: Tue May 24, 2011 4:36 am
I'm fairly sure the drain plugs are different also. WT has a ring around the plug, and a square drive grub screw style plug. All earlier models (ie NT) are just like a hex head bolt.
Clearance Hole Technology :P
Post Posted: Tue May 24, 2011 5:30 am
thanks for the info guys they look to be NT by the sounds of it cheers
Users browsing this forum: Google [Bot] and 203 guests
