It is currently Fri Oct 02, 2026 1:08 am
Post Posted: Wed May 25, 2011 2:18 am
hey guys, im new to 4x4 and ive got a 94' sierra and i was going to do a 2 inch lift and put 31's on it, was wondering if thats a good option? do i have to change the gearing?
Post Posted: Wed May 25, 2011 2:27 am
you will want to do gearing with 31s
Post Posted: Wed May 25, 2011 2:42 am
You'll also need a body lift, guard work or bumpstop spacers to run 31s without scrubbing...
I want my old sig back :(
Post Posted: Wed May 25, 2011 3:14 am
I've got 31's, 2" spring lift and 30mm bumpstop spacer on the front. No scrubbing. I've got a 1ltr transfer swell to counter the gearing. Not the best option but goes great in the bush!
Post Posted: Wed May 25, 2011 3:15 am
IMO 31s are well worth the bit of effort to make them work well, but, your in Qld, better check on what you can do, far as I know, a 2" lift is max.
Post Posted: Wed May 25, 2011 3:18 am
Nope, thats not correct. we have some rules about bumpstop spacing and shock lengths.
the biggest issue will be that 31s are illegal as a size on a zook in QLD.
legally you can only go to a tires 15mm over standard size
Vehicle: Daisy
Post Posted: Wed May 25, 2011 6:18 am
Would it pass a roadworthy with larger tyres?
I only ask because mine came with a roady and 29's which until I read enough on here I thought were stock (looks right because of suspension lift and body lift) and I'm beginning to think the bloke that roadworthy'd it was dodgy...
Post Posted: Wed May 25, 2011 9:00 am
It shouldnt have passed.. But there are alot of places out there that dont know the rules at all.
Is your body lift all legit with QLD transport?
Hell my jimny was passed with a slipping clutch, leaking rear main and heaps of play in the king pin bearings.
Vehicle: Daisy
Post Posted: Wed May 25, 2011 10:02 am
I have NFI, but I'm not going to drive in and ask them till the truck is all fixed up, what do you have to do to get it legit?
Users browsing this forum: Google Adsense [Bot] and 195 guests
