http://auszookers.com/forum/
body swap or engine/gearbox swap
http://auszookers.com/forum/viewtopic.php?f=5&t=22277
Author:  mudvit [ Wed May 25, 2011 12:02 pm ]
Post subject:  body swap or engine/gearbox swap
hi i have two vitaras one 1990 hardtop body in bad condition and a 1991 softop the hardop is running good engine/gearbox and rego softop has hacked up engine loom and no gearbox or engine and no rego both carby both black softop body is immaculate just wondering if im better off doin a bodyswap or putting my engine/gearbox and wiring combo into the softop and changing tags or simply doin a bodyswap as i also want a softop????
Author:  Fatzook [ Wed May 25, 2011 12:10 pm ]
Post subject:  Re: body swap or engine/gearbox swap
Same same. Do you have the lifting gear required to swap the cab?
Author:  alexvitara [ Wed May 25, 2011 12:13 pm ]
it would depend on which one has the better chassis and running gear wouldnt it
Author:  mudvit [ Wed May 25, 2011 12:23 pm ]
well there both about the same ive got a way to lift the body also and am goin to put a bodylift in so i figured that a body swap could be the way to go. cheers
Author:  mudvit [ Wed May 25, 2011 12:30 pm ]
just not sure wats more work as i want out of it the easiest quickest way and as i said am lookin at doin a bl at the same time
