It is currently Fri Sep 25, 2026 11:30 pm
Post Posted: Wed May 25, 2011 11:11 pm
Have purchased a complete Jimny power steering setup to transplant into the Sierra. After reading the posts about how it all just bolts up have came across a problem.
There's 3 mounting points on the pump bracket (I'm informed its from a 13bb) and only the top two of these line up on the Sierra block - see photos.
Whats the solution people?
I don't have the belt adjuster either, presume this will bolt on correct?
Post Posted: Thu May 26, 2011 7:08 am
Should be 4, I have both BB & B eng's here so I went for a lil walk to looky..
The bottom bolt for the BB doesn't exist on the older B block.
There also should be a smaller hole that bolt to the front of the block, if you have those 3 ( top 2 & front one ) IMO that will be enough...
Or just mark a third hole where you have a thread in the block & drill a third hole in the bracket..
Post Posted: Thu May 26, 2011 11:17 pm
Thanks for that - appears I've got the older block so will have to see if I can drill a hole in the bracket for the 3rd mounting bolt.
Users browsing this forum: No registered users and 153 guests
