It is currently Sat Sep 26, 2026 8:42 am
Post Posted: Sun Feb 27, 2011 9:53 am
hey all i was driving my 2ltr v6 auto vitara down the highway yesterday and the engine light came on for a bit and turned off it done it a couple of times i checked the owners manual and it says something about emission control how to i diagnose this or fix it
cheers scott
Post Posted: Sun Feb 27, 2011 10:10 am
welcome to AZ scottmcguinness172
it could be a number of things that's caused the CEL (check engine light) or MIL (malfuction indicator light) to come on under those conditions, one of the most common causes is a lazy o2 sensor.
to retrieve the error codes from the ecu, you need to make a suzuki special tool, the diagnostic tool numberis #564425681687934... :lol:
mine is made from some thin wire & covered in electrical tape & heat shrink. 8)
attached is a word document explaining how to retrieve the error codes. let us know how you get on with the codes, there is a universal o2 sensor that can be used for about $100 or a genuine one at around $330.
Post Posted: Sun Feb 27, 2011 7:11 pm
could i just use a paper clip like ya use on the commodores?
Post Posted: Sun Feb 27, 2011 7:31 pm
:lol: .... yep. Atari has waaaaay over-engineered his tool. 8O
Post Posted: Mon Feb 28, 2011 6:59 am
ya could mass product and sell that badboy :P
Post Posted: Mon Feb 28, 2011 7:01 am
kwuality not kwuantity
Post Posted: Tue May 17, 2011 12:54 am
Which pins do I jump to retrieve error codes?
Post Posted: Tue May 17, 2011 1:23 am
Looks like the word document didn't attach.. on my above post.
Post Posted: Tue May 17, 2011 10:55 am
cheers scott
L/h o2 sensor........ got me buggered why, but the gv's do the same thing, always the l/h one.... :crazy:
Post Posted: Tue May 17, 2011 5:29 pm
There's 2 on the J20s?
Mine went on the G16B - got CEL after a few minutes at 100kmh. Easy to replace and hasn't happened since.
Post Posted: Tue May 17, 2011 7:43 pm
by the fact he is saying l/h would suggest to me he is talking about the v6
they have one on each side one of mine needs replacing im guessing left hand just gotta have the time and money to do it
Post Posted: Tue May 17, 2011 9:06 pm
i have changed both oxy sensors i got universal ones had to wire them up my self it is still REALLLLYYY heavy on fuel thats why i want to see which wires i have to jump to throw the codes
cheers
Post Posted: Tue May 17, 2011 10:58 pm
How heavy are u talking? Also do you have the part number for those o2 sensors? Is yours the v6?
Post Posted: Wed May 18, 2011 2:35 am
cheers
download the attached word doc from my post above, it's all in there.
Post Posted: Wed May 18, 2011 10:39 am
cheers
Good luck with that..... :helloo:
Post Posted: Wed May 18, 2011 10:43 am
cheers
my original one lasted 70,000kms, my universal Bosch lasted 80,000kms. I know what I'll be putting back in.
Post Posted: Wed May 18, 2011 10:45 am
cheers
big difference between that & a rico special..
I have never had success with multi fit's, to the point I wouldn't fit em.....
Post Posted: Wed May 25, 2011 11:43 am
ok i done the diognistics and it flashed code 12 i looked up on the attachment and apparently its all good ok what is the next step to getting falt codes or working out why its chewing so much bloody fuel i got 200ks out of 3/4 of a tank on 215/75s whats the go with it??????????
Post Posted: Wed May 25, 2011 11:53 am
blocked cat? :?
Post Posted: Wed May 25, 2011 12:11 pm
could the timing be out,knock sensor? it is was rooted it would throw codes? i have reset the computer i cant pull the cat off and knock the guts out of it then it wont be blocked :twisted:
Post Posted: Thu May 26, 2011 6:44 am
I'm not saying you should do that, but I would.... :lol:
If the knock was buggered it would ping under heavy acceleration...
Post Posted: Thu May 26, 2011 9:08 am
It's not pinging or anything it hasn't thrown codes since I done the oxy sensors so I have no idea of what to do now
Users browsing this forum: Google [Bot] and 434 guests
