It is currently Sat Aug 01, 2026 6:23 pm
Vehicle: Yellow Ute
Post Posted: Mon May 30, 2011 7:46 am
G'day,
Just wondering if anyone has upgraded the drum brakes on an SJ40 to disc brakes. What they used? And how they did it?
Thanks,
Jackson
Post Posted: Mon May 30, 2011 7:53 am
you can use the disk brake setup from a later model 1 litre or any 1.3
Vehicle: Yellow Ute
Post Posted: Mon May 30, 2011 7:56 am
So that would bolt straight on?
Does it matter if the disc brake setup comes off a wide track?
Thanks,
Jackson
It's a straightforward swap. After buying my 1.0 with a drum front end, I never put it on the road with drums - I swapped discs straight into it.
Post Posted: Mon May 30, 2011 10:27 am
I got 1lt diffs complete with brakes you can have for free
 Profile YIM
Vehicle: Yellow Ute
Post Posted: Tue May 31, 2011 7:23 am
One more quick question. Would I be correct in thinking that I will need a disc brake model master cylinder?
Post Posted: Tue May 31, 2011 8:34 am
and a brake booster
 Profile YIM
Post Posted: Tue May 31, 2011 11:15 pm
you could get a 1.3 master cyl with booster, but i have been told they bolt up differently.
You would be better off getting a master cyl off a late model 1 litre with disk brake front but no booster. If buying a new one tell them you want one for an 84 1 litre. (yes drum to disk is a different master cyl, but i dont know how it would affect braking performance, if at all.
Post Posted: Wed Jun 01, 2011 1:47 pm
jimbo_jones wrote:
and a brake booster
No, the 1.0lt don't run a brake booster with discs. The replacement SJ410 M/C from Suzistore is the Disc Brake version, seems the drum version is very hard to find new or aftermarket..
Although the firewall to pedal dimensions are the same, the Boosted master cylinders bolt up very differently and will require modifying your firewall.
Users browsing this forum: Google [Bot] and 364 guests
