It is currently Wed Nov 04, 2026 10:43 am
Post Posted: Fri Jun 03, 2011 8:02 am
I have two of these and i was keen on putting them in, but i have read somewhere that they have a valve in em, so if you flick the switch without putting you foot on the brake then put your foot on the brake, it feeds more pressure in and holds it there. i just don't know which way they flow...
and because im a genious with electric's i was wondering if this needs relay?
Post Posted: Fri Jun 03, 2011 8:07 am
why do you have two???
Post Posted: Fri Jun 03, 2011 8:08 am
rear digg....
Post Posted: Fri Jun 03, 2011 8:16 am
I see :blink:
Post Posted: Fri Jun 03, 2011 8:24 am
I recon MC in like on that pic is the master cylinder side :)
no need for a relay
Post Posted: Fri Jun 03, 2011 9:01 am
I know you sent me a PM about this I was too busy to respond to.
Royce is on the money for the direction.
Yes you are right. You can turn it on an leave it on, and the first time you punch the brake it stays on.
I run a relay on mine. I also run two switches on mine - the momentary switch on the gear lever and a normal rocker switch so I can use it as a short term handbrake.
I also run an indicator light loud and proud on the dash.
I wired mine directly off the battery. You don't want the line lock releasing if you turn the key off if you are using it as a handbrake.
Post Posted: Fri Jun 03, 2011 10:05 am
mine don't have MC/in written on em, ok cheers guys, and Gwagen, it's cool, i figured as much, no harm done. good point about the direct battery line also.
so relay V's no relay? still got two different answers.....
Post Posted: Sat Jun 04, 2011 4:24 am
so.... :D
Post Posted: Sat Jun 04, 2011 4:28 am
There's no real need to fit a relay, they only consume about 2 amps, but adding one isn't a bad idea either - there's no disadvantage to running a relay IMHO.
Post Posted: Sat Jun 04, 2011 5:03 am
ok, thanks steve :D
Users browsing this forum: Google [Bot] and 138 guests
