It is currently Sun Nov 01, 2026 5:44 pm
Post Posted: Sat Jun 04, 2011 5:54 am
Hi all, anyone have links or pictures of g16a carby set-up including all hose placement???? Cant seem to find any pictures to help me out?!?
I also bought another carby but is missing the feul in and return inlets??? anyone know if there are other carby's and can I rout the return back on itslf and fit the replacement???
Post Posted: Sat Jun 04, 2011 7:23 am
I have decided to sell the replacement carby and find the same one.....
Post Posted: Sat Jun 04, 2011 9:35 am
anyone with info????
Post Posted: Sat Jun 04, 2011 9:50 am
i can take some pics for you tomorrow if you want but i wont be taking to air filter off so it probably wont help much
Post Posted: Sat Jun 04, 2011 11:55 am
any help is appreciated, just want to check routing... cheers
Post Posted: Sat Jun 04, 2011 11:57 am
ok i'll get a pic tomorrow and post it up
Post Posted: Sun Jun 05, 2011 12:00 am
Is it a Hitachi?
I have the US Spec. vacuum line map:
http://www.acksfaq.com/Samvacuumlines.htm
(Found by doing a search for vacuum at http://www.acksfaq.com
I hope that this helps!
-Ack
88, 88.5 SJ413
Post Posted: Sun Jun 05, 2011 1:23 am
thanks for the link but I am running a Mikuni Carb,, ill check if they have the same setup
Post Posted: Sun Jun 05, 2011 1:38 am
Sweet link, almost all the same setup ill def use this link to help... thanks to the yanks...
Post Posted: Sun Jun 05, 2011 10:49 am
probably wont help but here you go anyway
from the front
from the side
Post Posted: Sun Jun 05, 2011 11:17 am
Spot on champ, what would be the chances of getting a pic of the dizzy rout (mine runs to the 3 pronged doobie on side of carby) and center canister rout (mine runs to same 3 point junction?) is that correct?
Post Posted: Sun Jun 05, 2011 11:25 am
huh? :blink:
Post Posted: Sun Jun 05, 2011 11:51 am
Sorry not sure what the junction is called its on the side closest to the motor and has 3 small hoses running from it, to dizzy, to canister and the other to the brown valve (VSV i think) in your first picture that runs to the EGR
Post Posted: Sun Jun 05, 2011 12:20 pm
i'll have a look tomoro for you mate but i dont really understand what you mean
Users browsing this forum: Andygoodbloke, Google Adsense [Bot] and 422 guests
