| need some Altenator advice!!! http://auszookers.com/forum/viewtopic.php?f=5&t=22527 |
| Author: | stocker [ Sat Jun 04, 2011 6:29 am ] |
| Post subject: | need some Altenator advice!!! |
gday fellow auszookers... My quick question. Can connecting the wires back to front on the exciter of an altenator cause it to charge the battery at 17.4 volts??? Cheers |
| Author: | Teracis [ Sat Jun 04, 2011 6:35 am ] |
| Post subject: | Re: need some quick advice |
Have you got a multimeter? Fire the thing up with the meter hooked to it and check? |
| Author: | royce [ Sat Jun 04, 2011 6:35 am ] |
internally in the alternator? or by back to front you mean swapping the sense wire and the indicator light into the back of the alternator? |
| Author: | stocker [ Sat Jun 04, 2011 7:04 am ] |
sense wire and indicator light |
| Author: | 89_tintop [ Sat Jun 04, 2011 7:23 am ] |
It can cause damage to the regulator.. Sounds like that may have happened. |
| Author: | stocker [ Sat Jun 04, 2011 10:12 pm ] |
| Author: | 89_tintop [ Sat Jun 04, 2011 10:15 pm ] |
What alternator do you have |
| Author: | stocker [ Sun Jun 05, 2011 2:41 am ] |
falcon mitsu 100 amp jobby, |
| Author: | stocker [ Sun Jun 05, 2011 3:24 am ] |
| Author: | stocker [ Sun Jun 05, 2011 3:39 am ] |
ok so i managed to get on the computer lastnight and have a good read over the tech advice on installing one of these alt's. I do have the sense wire and batt light wire the correct way around now the problem im faced with. For some reason at idle i have almost no voltage coming from the alt it sits around 12.4 volts. The second you give it a little throttle the charge jumps up to 18+ volts. Ive tried it whilst under load (spotties and hibeams) on and it makes neglidgable difference i assume this could mean the regulator is fried??? Any help or confirmation would be appreciated |
| Author: | stocker [ Sun Jun 05, 2011 9:57 am ] |
| Post subject: | Re: need some Altenator advice!!! |
Anyone??? |
| Author: | jdk81 [ Sun Jun 05, 2011 10:00 am ] |
sounds like reg is fudged |
| Author: | Junior_91 [ Sun Jun 05, 2011 10:45 am ] |
i had a similar problem but only went to 14.9 volts, all i did was hook sense wire directly to the battery i think. Wont go about 14.2 now |
| Author: | stocker [ Mon Jun 06, 2011 8:37 am ] |
hmm... i tried hooking them up both ways... one way, 18 Plus volts, the other way, i get 15.2Volts... Time to price a new Reg... |
