| 1.6 conversion need help http://auszookers.com/forum/viewtopic.php?f=5&t=22591 |
| Author: | AxL_ [ Mon Jun 06, 2011 9:00 am ] |
| Post subject: | 1.6 conversion need help |
hi guys i cooked my 1 ltr wana go the 1.6 vit "g16b'' i think need to no what has to be done and if i need a 1.3 5 speed or the stock vit box |
| Author: | boostedbrick [ Mon Jun 06, 2011 9:06 am ] |
| Post subject: | Re: 1.6 conversion need help |
Some good info in here. AFAIK going from a 1ltr is more involved than from a 1.3.. Someone can confirm this. http://www.auszookers.com/index.php?nam ... pic&t=4853 |
| Author: | xedent [ Mon Jun 06, 2011 9:10 am ] |
Yes, engine mounts are in different spots then a 1.3L, Depending on what 1l sierra it is so are the gearbox mounts and the tunnel is also smaller. |
| Author: | zooky08 [ Mon Jun 06, 2011 9:11 am ] |
Yea engine mounts need to be changed nd pretty sure the nt 1lt have a smaller tunnel so the 1.3 5speed might not fit Some one confirm this. Yes or no? |
To slow |
| Author: | Gwagensteve [ Mon Jun 06, 2011 9:20 am ] |
Skip the 1.3 5 speed and go straight to the Vitara transmission - if you have to do tunnel work anyway, do a bit more and avoid the smaller clutch/adapter plate. Steve. Yes, all mounts will have to be moved. |
| Author: | jimbo_jones [ Mon Jun 06, 2011 10:19 am ] |
Gwagensteve wrote: Skip the 1.3 5 speed and go straight to the Vitara transmission - if you have to do tunnel work anyway, do a bit more and avoid the smaller clutch/adapter plate.
Steve. Yes, all mounts will have to be moved. if you do a 2" body lift will the 1.3 box fit ok? |
| Author: | Gwagensteve [ Mon Jun 06, 2011 11:05 am ] |
I think so. Steve. |
| Author: | shandy92 [ Mon Jun 06, 2011 1:18 pm ] |
he is already running a body lift, not quite 2" but some home made thing. |
| Author: | BlueSuzy [ Mon Jun 06, 2011 1:35 pm ] |
Lower the engine mounts and you wont need a bodylift. Also depends on sump clearance. |
| Author: | AxL_ [ Tue Jun 07, 2011 1:36 am ] |
Thanks for the feed back im sure to have a faster zook in the comeing months |
| Author: | Fatzook [ Tue Jun 07, 2011 2:16 am ] |
Steve. Yes, all mounts will have to be moved. X2. SIerra 5sp is a bag of shit |
