It is currently Tue Sep 22, 2026 10:25 am
Post Posted: Tue Jun 07, 2011 3:41 am
Hey guys just wandering if you guys can help me out with an issue involving my spotties
They worked fine, were hooked up to high beam with a switch also. Everything was good until last night I flicked the switch and the spotties wouldn't turn on, but even worse now my highbeams won't work. Low beam r fine but As soon as I turn highbeam on my lights turn out. Cept my parkers.... Any ideas?
If in doubt power out!
Post Posted: Tue Jun 07, 2011 3:50 am
i assume you checked all of the fuses before posting? :wink:
High beam fuse popped/fallen out?
I can't remember if sierras have a separate fuse for low and high.
I would start from there and work back.
Does high beam work with the spotties switched off?
Was high beam working then you switched on thespotties and it went out?
All this will help fault find.
I drive my Daihatsu like its a Suzuki!
Post Posted: Tue Jun 07, 2011 3:52 am
All fuses checked. Even replaced the relay...
And highbeams aren't working even with spotties switched off
Post Posted: Tue Jun 07, 2011 3:54 am
does high beam work when you pull the switch back to the passing flasher?
memory high beam under teh dash is red/white, find that going into the dip switch and stick your test light on it to see if the light glows and your spotties come on, might be the switch is gummed up
Post Posted: Tue Jun 07, 2011 6:34 am
What part of brissie you in mate?
sounds like the switch is faulty.
try pulling the switch back to the "flash" positon and see if the high beam come on.
Vehicle: 1.6 SJ80
Post Posted: Tue Jun 07, 2011 8:39 am
How have you set up your spotties? Used a relay and used the factory earth to switch it? I would be thinking it is either a dodgy switch not allowing you to send power to the highbeam circuit or a dodgy earth on the highbeam. Maybe try run another earth?
Post Posted: Wed Jun 08, 2011 12:04 am
The switch from low beam to highbeam maybe? The blue light on the dash isn't coming up:/
Post Posted: Wed Jun 08, 2011 3:16 am
Seems the switch for the highbeam on my Sierra is stuffed or the relay is cactus
But no idea where the relay is...
Anyone wanna come have a look or have pictures they can show?
Need my spotties for this weekend
Post Posted: Wed Jun 08, 2011 7:47 am
If your near the goldcoast I will look at it for you...
Users browsing this forum: No registered users and 232 guests
