It is currently Sat Oct 31, 2026 2:28 am
Vehicle: Suzuki Grand Vitara
Post Posted: Sat Jun 11, 2011 3:20 am
What is the Spark Plug Gap for my 1995 Vitara, 1.6 EFI.
NGK - BKR6E
Can find my workshop book.
..............is it 0.7 to 0.8mm..??
Post Posted: Sat Jun 11, 2011 3:30 am
Should be 0.8mm. Why do you need to gap them?
Post Posted: Sat Jun 11, 2011 3:32 am
Should be gaped from factory, but know knows if someone hasn't dropped one, etc.
Post Posted: Sat Jun 11, 2011 4:33 am
I've never had an issue with NGK plugs. They come with that protective tube
Post Posted: Sat Jun 11, 2011 4:57 am
Checked them and they where all 0.9
Old plug where a bit white might be running lean.
Post Posted: Sat Jun 11, 2011 5:48 am
I check new plugs even, as the manufacturer states, "should" be fine.
For the few secs it takes to check, great piece of mind.
Every oil change, I check them as well.
Usually perfect, but it takes bugger all time, and it will forecast a possible problem developing.
I run my plugs at 1.25mm, thats on a carby 1.3l
Vehicle: Jeep
Post Posted: Sat Jun 11, 2011 8:16 am
I Always gap new plugs, never had one new out of the box, set to the correct gap... :roll:
Hmmm 1.25mm is a pretty big gap 8O be careful your coil doesnt run too hot and burnout... but with a gap that big, it must ignite the fuel very well... :roll: :lol:
Post Posted: Sat Jun 11, 2011 3:01 pm
I think it does, but, i have a big fat coil.
Post Posted: Mon Jun 13, 2011 2:17 am
Here is a coulpe of pics of the spark plugs.
Post Posted: Mon Jun 13, 2011 6:49 am
look nice to me, I posted a link here once about reading plugs and what things like that heat mark on the ground mean and so on
Post Posted: Mon Jun 13, 2011 7:20 am
Here's one guide
http://www.ngkspark.com.au/sparkplug_tech.php#
Under "Spark Plug Analysis"
Post Posted: Mon Jun 13, 2011 7:28 am
This is a thread I posted up a while ago regarding plugs
http://www.auszookers.com/index.php?nam ... spark+plug
Lil Foot!
Vehicle: Jeep
Post Posted: Mon Jun 13, 2011 7:56 am
Those plugs look like they are burning well... but i did notice some rust on the thread of the plug, could be nothing, but you might want to keep an eye on that.. :D
Post Posted: Mon Jun 13, 2011 8:21 am
lol its impossible to to have rust on a plug thread in an alloy headed engine, its probably anti seize (in which case it needs more)
Users browsing this forum: No registered users and 491 guests
