It is currently Wed Oct 28, 2026 2:08 am
Post Posted: Fri Jun 10, 2011 8:46 am
hi guys. just put new pads and wheel cylinder in my 1990 sierra. now i cant get the brake drum cover thing back on. how do i get it on again?
maybe i put the stuff in the wrong way?
Post Posted: Fri Jun 10, 2011 8:48 am
Did you adjust the adjuster all the way back in?
Are the shoes "centred" correctly??
Post Posted: Fri Jun 10, 2011 8:51 am
Have you reset the handbrake adjuster?
You need to stick a flat blade screwy into the cam ratchy thingy (auto handbrake adjuster) for the handbrake to reset.
SS
Vehicle: 2018 DMAX
Post Posted: Fri Jun 10, 2011 8:54 am
Handbrake not on still? I did that once, took awhile to realise :oops:
Post Posted: Fri Jun 10, 2011 9:11 am
havent readjusted the handbrake. will check it now. handbrake doesnt work from being too loose or something the guy i got it off said. il release that thing now if i can work it out
Vehicle: '96 LWB trayback
Post Posted: Fri Jun 10, 2011 9:18 am
Let off the handbrake, wind both adjusters all the way inwards, centre the shoes.
The drum should slide over with perhaps some gentle persuasion from a small hammer.
You didn't order oversized shoes by mistake? The come in a regular size and a larger size to suit drums that have been machined smooth.
Post Posted: Fri Jun 10, 2011 11:27 am
i had the handbrake disconnetcted from it since the start.
i couldnt get the drum over the new pads with the shoes the way i thought they went so changed them around and i could get it on with a hammer. but when i tightened up the drum case onto it it full locked the whole thing from spinning.
so i put it back together the way i thought it goes with the original pads but there very low so gotta find out how to do it soon.
i put it back together as per the other side coz i couldnt remember how it was.
i mainly pulled it apart to change a leaky wheel cylinder so thats in now but will have to do the brakes very soon
Post Posted: Fri Jun 10, 2011 11:28 am
the pads are from suzisport
53210-78000
sierra wt shoes
is what it says on the label
Vehicle: lj81 stockman
Post Posted: Fri Jun 10, 2011 12:07 pm
i can give u a hand tomoro after 5 if u want ether your place or my work shop
the wobble rocks
Vehicle: WR250F/Jeep XJ
Post Posted: Fri Jun 10, 2011 1:07 pm
sometimes can be a pain in the ass mate last set i did i stuffed aroudn with it for ages to get the pads centred and then just bolted everything together and went for a drive...was pretty bad early on but it loosened up after a while. not an ideal solution but i think they remanufacture some pads a little thick....
LIKE US ON FACEBOOK - KPD4x4
Vehicle: Daisy
Post Posted: Fri Jun 10, 2011 9:48 pm
Did you push the pistons on the cylinder back in to bring the pads closer to the centre?
Also I'm pretty sure the FSM says the maximum thickness of the pad.
Users browsing this forum: Google [Bot] and 312 guests
