| Spark Plug Gap for Vitata needed please. http://auszookers.com/forum/viewtopic.php?f=5&t=22753 |
| Author: | suzukiboy [ Sat Jun 11, 2011 3:20 am ] |
| Post subject: | Spark Plug Gap for Vitata needed please. |
What is the Spark Plug Gap for my 1995 Vitara, 1.6 EFI. NGK - BKR6E Can find my workshop book. ..............is it 0.7 to 0.8mm..?? |
| Author: | Scrawny [ Sat Jun 11, 2011 3:30 am ] |
| Post subject: | Re: Spark Plug Gap for Vitata needed please. |
Should be 0.8mm. Why do you need to gap them? |
| Author: | suzukiboy [ Sat Jun 11, 2011 3:32 am ] |
Scrawn wrote: Should be 0.8mm. Why do you need to gap them?
Should be gaped from factory, but know knows if someone hasn't dropped one, etc. |
| Author: | Scrawny [ Sat Jun 11, 2011 4:33 am ] |
I've never had an issue with NGK plugs. They come with that protective tube |
| Author: | suzukiboy [ Sat Jun 11, 2011 4:57 am ] |
Checked them and they where all 0.9 Old plug where a bit white might be running lean. |
| Author: | SuziBlu [ Sat Jun 11, 2011 5:48 am ] |
I check new plugs even, as the manufacturer states, "should" be fine. For the few secs it takes to check, great piece of mind. Every oil change, I check them as well. Usually perfect, but it takes bugger all time, and it will forecast a possible problem developing. I run my plugs at 1.25mm, thats on a carby 1.3l |
| Author: | MacDaddy [ Sat Jun 11, 2011 8:16 am ] |
SuziBlu wrote: I check new plugs even, as the manufacturer states, "should" be fine.
For the few secs it takes to check, great piece of mind. Every oil change, I check them as well. Usually perfect, but it takes bugger all time, and it will forecast a possible problem developing. I run my plugs at 1.25mm, thats on a carby 1.3l I Always gap new plugs, never had one new out of the box, set to the correct gap... Hmmm 1.25mm is a pretty big gap |
| Author: | SuziBlu [ Sat Jun 11, 2011 3:01 pm ] |
I think it does, but, i have a big fat coil. |
| Author: | suzukiboy [ Mon Jun 13, 2011 2:17 am ] |
Here is a coulpe of pics of the spark plugs.
| Author: | royce [ Mon Jun 13, 2011 6:49 am ] |
look nice to me, I posted a link here once about reading plugs and what things like that heat mark on the ground mean and so on |
| Author: | Scrawny [ Mon Jun 13, 2011 7:20 am ] |
Here's one guide http://www.ngkspark.com.au/sparkplug_tech.php# Under "Spark Plug Analysis" |
| Author: | JrZook [ Mon Jun 13, 2011 7:28 am ] |
This is a thread I posted up a while ago regarding plugs http://www.auszookers.com/index.php?nam ... spark+plug |
| Author: | MacDaddy [ Mon Jun 13, 2011 7:56 am ] |
suzukiboy wrote: Here is a coulpe of pics of the spark plugs.
![]() Those plugs look like they are burning well... but i did notice some rust on the thread of the plug, could be nothing, but you might want to keep an eye on that.. |
| Author: | royce [ Mon Jun 13, 2011 8:21 am ] |
lol its impossible to to have rust on a plug thread in an alloy headed engine, its probably anti seize (in which case it needs more) |
