It is currently Fri Oct 09, 2026 8:43 pm
Post Posted: Sat Jun 11, 2011 5:58 am
just in the middle of a rebuild on the g16a. does anyone no if you can get better or bigger oil pumps for these motors.
Vehicle: 03 Jimny
Post Posted: Sat Jun 11, 2011 6:32 am
The standard oil pump will be fine
Vehicle: 90 Vitara
Post Posted: Wed Feb 13, 2013 8:08 am
Sorry to fire up an ancient post but I'm about to have my oil pump gasket replaced at Ultra Tune tomorrow.
I need to know does the sump have to come off to get the oil pump off?
I ask as it will change a 2hr job to a 5hr job :(
Post Posted: Wed Feb 13, 2013 9:22 am
Yes it does due to the two studs in the bottom of the pump preventing it coming straight forward.
Post Posted: Wed Feb 13, 2013 10:56 am
Anyone ever heard of this gasket leaking? would be a first for me
If youve got oil around the front perhaps look at the crank seal
Vehicle: 90 Vitara
Post Posted: Wed Feb 13, 2013 11:06 am
Yeah it doesn't see to be crank. There's an alcove top left edge of the pump by the water pump join and seems to be oozing there. Either way both gasket and crank seal will be replaced. Just hoped not another full $500 excercise after just cost $500 to fix two broken sump bolts and reseal sump.
Post Posted: Wed Feb 13, 2013 9:34 pm
last time i seen an oil leak pool in the top of the oil pump wasnt the gasket on the oil pump ... it was leaking down from the head gasket where the oil feeds the cylinder head .
I have seen oil leaks from an oil pump gasket before , but it was from when the oil pump was pulled away from the block by an incorect tightening sequence of ancillery brackets.
Vehicle: 90 Vitara
Post Posted: Thu Feb 14, 2013 5:51 am
Interesting and scary. Pretty sure its not the head. pray it isn't the head!
As for the tightening it would be rather apparent early after rebuild rather than years and years later would it not?
Users browsing this forum: Google [Bot] and 156 guests
