It is currently Tue Nov 03, 2026 1:52 pm
Post Posted: Mon Jun 13, 2011 3:48 am
Just put another carby on the zook and it idles perfect but when I put my driving lights on the revs climb to 15-1600 any ideas?
94 SWB Vitara
Yer I Can Find You...
Post Posted: Mon Jun 13, 2011 5:34 am
Idle up solinoid is on the front of the carb. It runs a vacuum pot with a long linkage to the throttle shaft. Have someone turn the fan on whilst you are watching the linkages. You will see the setscrew and turn this out until idle drops to around 1000rpm.
Post Posted: Mon Jun 13, 2011 7:16 am
This is done while I'm running the car? Will this change the revs when the lights are off as they are at 800
94 SWB Vitara
Post Posted: Mon Jun 13, 2011 2:42 pm
Yes only adjust the idle up when the car is running so you can get it to the preffered rpm. When your acc.- blower, lights Are switched off the idle will return to normal idle rpm (800rpm)
Users browsing this forum: No registered users and 489 guests
