It is currently Thu Oct 29, 2026 10:41 pm
Vehicle: 4wd
Post Posted: Thu May 26, 2011 2:13 am
I pulled my case apart the other day, but the countershaft was stuck. I removed the locking tab on the outside of the case but the shaft won't budge.
Any trick on getting it out?
Watch out or you'll get sued.
Post Posted: Thu May 26, 2011 2:26 am
WD40 and tap with hammer?
Lil Foot!
Post Posted: Thu May 26, 2011 2:29 am
Hit it.
If that doesn't work, hit it harder!
I want my old sig back :(
Post Posted: Thu May 26, 2011 2:37 am
Ben_Sierra wrote:
Hit it.
Don't use force, use a bigger hammer. :mrgreen:
Post Posted: Thu May 26, 2011 2:38 am
SuziBlu wrote:
Ben_Sierra wrote:
Hit it.
F=m*a how can you not use force? :P
Lil Foot!
Vehicle: 4wd
Post Posted: Thu May 26, 2011 2:59 am
I only tried the strong arm. I will try hammer next!
Post Posted: Thu May 26, 2011 3:00 am
JrZook wrote:
SuziBlu wrote:
Ben_Sierra wrote:
Hit it.
Bigger hammer, less acceleration, same force :P
Post Posted: Thu May 26, 2011 3:27 am
lol was meant as a silly, but instead of smacking the shit out of it with a light hammer, let inertia do the job, use a bigger hammer, swung with good force, much more inertia.
Always use a brass drift, never steel on steel.
Post Posted: Thu May 26, 2011 7:15 am
Has an O'ring on the end, could have corosion in there to, so wd or similar & a lil love tap should see you clear... :helloo:
Post Posted: Thu May 26, 2011 8:33 am
I find that swearing at it and graphically describing sexual acts I would do to its mother helps things along.
Post Posted: Thu May 26, 2011 9:17 am
threaten it with a 9 inch. :shocked: .. grinder
Post Posted: Mon Jun 13, 2011 3:47 am
Why does the counter shaft protrude through the case, thus needing an 'O' ring? Is there a maintenance reason for this?
Users browsing this forum: Google [Bot] and 361 guests
