It is currently Tue Nov 03, 2026 7:32 pm
Post Posted: Mon Jun 13, 2011 10:27 am
Ok Gents here i go again. I am in the process of doing maintenance on my vit and now im at the stage of wanting to have a look at how much meat is left on my rear brakes, trouble is after taking off my tyre how the hell do you remove the steel cover that encloses the internals where the shoes lie. I can see a thread in the middle of the drum, does this have a use? Thanks Ray
Vehicle: Suzukiless these days..
Post Posted: Mon Jun 13, 2011 10:34 am
theres two holes to put bolts and a puller in............
Or I just take a hammer to the case and tap it lightly with the handbrake of , turning as I go and it normally falls of.
goddamitmyspacebarsbrokenagain
Post Posted: Mon Jun 13, 2011 11:15 am
undo the 4 bolts, make sure the hand brake is off then hit the drum on the face at opposite points
Post Posted: Mon Jun 13, 2011 11:46 am
ok but there are no four bolts only a thread right in the middle of the hub
Post Posted: Mon Jun 13, 2011 11:55 am
there will be 2 threaded bolt holes in the drum just outside of the hub hole, screw a couple of bolts into these & it will push the drum off.
Post Posted: Mon Jun 13, 2011 12:04 pm
Yeah, I had the same trouble. Took me and the old man a while to figure that one out.
I think the holes have about a 12mm thread, but don't quote me on that.
What do you MEAN "That JCB won't fit"?!
Post Posted: Mon Jun 13, 2011 7:18 pm
i know there are threaded holes there on the rotors on the front not sure about the back though. easiest way is undo the 4 bolts that hold the drum on and put your wheel back on with 2 bolts take hand brake off and wiggle from the wheel (you get more leverage on it this way). i find i get no where with just hitting with a hammer.
Post Posted: Mon Jun 13, 2011 9:07 pm
Going by other threads this is a 96 vit, doesnt have bolt on drums, they slip over the wheel studs like normal cars
Post Posted: Mon Jun 13, 2011 11:32 pm
Yeah, the later model Vits have a pressure fit drum.
Users browsing this forum: No registered users and 442 guests
