It is currently Sat Nov 14, 2026 1:01 am
Post Posted: Sun Jun 12, 2011 10:22 am
Hey peeps. Long time no post. :helloo:
But anywayz onto the proper situation.
The last time I drove my suzy it sounded like a freakin airoplane and due to the fact that I am at uni now in a different place I haven't had a chance to sarse it out. So I thought i would do some research b4 i get back home.
Ummm it sounds like a aeroplane only when slight acceleration occurs...
One of my mates had the same issue for ages untill he realised that the tailshaft bearings had died a horrible death.
But yeah could this be a tailshaft bearing problemo or something else. And if it is could I do it myself or is it too difficult?
Cheers in advance :)
My build: Click WWW
Post Posted: Sun Jun 12, 2011 10:33 am
More description of the noise?
What kind of aeroplane? What kind of noise?
Have you fed it red bull lately? Heard that stuff gives u wings!
Post Posted: Sun Jun 12, 2011 10:41 am
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
THINKING BEFORE POSTING!!!
Post Posted: Sun Jun 12, 2011 10:59 am
if it sounds like the plane is coming into land from the rear, it could be either pinion bearings, wheel bearings, or a uni joint.
Vehicle: '94 suzuki maruti
Post Posted: Sun Jun 12, 2011 11:41 am
may sound like a stupid thing to say, but check the oil level before anything else... low level gave my sierra the symptoms your describing
Post Posted: Sun Jun 12, 2011 10:23 pm
What's a tailshaft bearing?
Steve
Post Posted: Sun Jun 12, 2011 11:07 pm
Steve
Uni's :wink:
Post Posted: Mon Jun 13, 2011 1:01 am
Steve
Uni's :wink:
Could be centre hanger bearing. No mention of vehicle type
Post Posted: Mon Jun 13, 2011 2:25 am
Scrawn wrote:
Steve
Uni's :wink:
Or in this case, a Propellor Shaft bearing, no mention if the plane is a Jet or Prop job.
Post Posted: Mon Jun 13, 2011 4:13 am
Ok well my vehimacle isn't ACTUALLY a plane.. :( Unfortunately.
But it sounds like a jet turbine crossed with a really whining sound.
(It is a 1990 SWB Sierra)
The sound is coming from the center back of the car.
And no I havn't checked oil or red bull levels yet. WHen you talk about oil level do u mean the dif oil? Or engine oil? Because engine oil is right.
My build: Click WWW
Post Posted: Mon Jun 13, 2011 7:36 am
Check the exhust for holes. Makes a wicked nasty load noise when there is a hole in the exhust before the muffler. (or if you put a straight thru with extractors and a hotdog resonator, it sounds like a evil lawn mower on crack :lol: )(yes, that is from experience :D)
Post Posted: Mon Jun 13, 2011 7:44 am
Is it like a loud whining noise? As in a rotating noise?
Get someone in the back and ask them to listen to the noise? Confim its in the rear? ( noises can sometimes sound like the rear when its actually at the front)
Is it only there when driving? When u rev it is it there?
Post Posted: Mon Jun 13, 2011 7:45 am
Check/ change diff oil. Best to change it if you haven't done it in a while.
Post Posted: Mon Jun 13, 2011 10:38 am
Umm no Muffler is fine. Except there must be a crack in it somewhere. Has opened up a couple of times and filled the cabin with smoke (Fortunately have had windows open so barely even noticed) But was intense smoke haha. Always happened on this one hill when I hit it at a certain speed.
Umm will get someone to double check it is come from back when I get home in a couple of weeks, Yeah as in a rotating noise. And no it isn't there when just reving in neutral.
Will also change diff oil, was going to do it before I left but ran out of time.
My build: Click WWW
Post Posted: Mon Jun 13, 2011 8:05 pm
yeah i meant diff oil, sorry i should have mentioned that. i know mine was noisy when it was low, or when its muddy.
Post Posted: Mon Jun 13, 2011 10:47 pm
I vote rear diff.
Post Posted: Mon Jun 13, 2011 11:18 pm
I vote rear diff.
X2
Either rear wheel bearings or pinion bearing
Mine made as you call it "areoplane" noise in my rear diff
Users browsing this forum: Google [Bot] and 59 guests
