http://auszookers.com/forum/
vitara rear diff strength?
http://auszookers.com/forum/viewtopic.php?f=5&t=23017
Author:  93zook [ Sun Jun 19, 2011 10:01 am ]
Post subject:  vitara rear diff strength?
gday guys. how strong is a vitara rear diff? is it going to be stronger than a sierra?
would it be able to run a 35 on rocks?
Author:  remydog05 [ Sun Jun 19, 2011 10:25 am ]
Post subject:  Re: vitara rear diff strength?
From what Im told the ring and pinon is stronger but the axles are similar strength.
Author:  zooker [ Sun Jun 19, 2011 10:29 am ]
There used to be a sierra back in wollongong running a vit rear diff and 37's. Don't think he had any issues
Author:  93zook [ Sun Jun 19, 2011 10:35 am ]
cool, recon a sierra front would hold up tp 35's with cromo axles?
Author:  zookcubr [ Sun Jun 19, 2011 10:40 am ]
If your using a vit rear diff in the rear, what are you using up front?
Author:  93zook [ Sun Jun 19, 2011 10:46 am ]
sierra...hopefully :wink: if the sierra diff cant handle 35's then ill just stick with 33's
Author:  Joe [ Sun Jun 19, 2011 10:47 am ]
Vitara diffs are wider then sierra
Author:  93zook [ Sun Jun 19, 2011 10:49 am ]
yeah thats cool, just means ill loose the spacers in the rear.
Author:  Brett [ Sun Jun 19, 2011 10:52 am ]
wrong off set for the center.
Author:  93zook [ Sun Jun 19, 2011 11:27 am ]
will that worry it too much you recon? the rear is 400mm longer and the drive shaft is about 920mm.
