| 33in tires http://auszookers.com/forum/viewtopic.php?f=5&t=23072 |
| Author: | Bennyzarb [ Mon Jun 20, 2011 9:35 am ] |
| Post subject: | 33in tires |
Will I be able to fit 33s under my 92 swb Sierra I have 2in lifted ome springs snake racing extended shackles and am installing a 2 in body lift soon |
| Author: | Rusho [ Mon Jun 20, 2011 9:37 am ] |
| Post subject: | Re: 33in tires |
Probably need a bit of guard clearancing also |
| Author: | Sutho [ Mon Jun 20, 2011 9:43 am ] |
and gears |
| Author: | boostedbrick [ Mon Jun 20, 2011 9:43 am ] |
Im not normally one to say this, but try searching mate.. Every thread you have in suzuki talk could have been answered by searching. I ran, 2inch springs, 2inch shackels, 2inch body with a 1inch guard chop to fit 33's. Bump stop spacers would have been desirable/ |
| Author: | Rusho [ Mon Jun 20, 2011 9:47 am ] |
Sutho wrote: and gears
That would also help |
| Author: | 31zook [ Mon Jun 20, 2011 10:06 am ] |
50mm BL, and a 4lb dumpy. X2 on searching |
| Author: | SierraDan [ Mon Jun 20, 2011 10:07 am ] |
31zook wrote: 50mm BL, and a 4lb dumpy. X2 on searching
Wanna help me fit some end of the year? |
| Author: | shep [ Mon Jun 20, 2011 10:08 am ] |
i have just fitted 33s. have 100mm spring/shackle lift on the front and 125mm on the rear plus a 25mm body lift. also wt diffs with nt spacing, front diff moved about 50mm froward. and 6.5 trans case. still need to do a lot of cutting especially on the front. i don't think there will be much of the headlight bucket left when i am finished. |
| Author: | 31zook [ Mon Jun 20, 2011 10:10 am ] |
SierraDan wrote: 31zook wrote: 50mm BL, and a 4lb dumpy. X2 on searching Wanna help me fit some end of the year? you can borrow my hammer |
| Author: | SierraDan [ Mon Jun 20, 2011 10:19 am ] |
Saweeeeet |
| Author: | TryHard [ Mon Jun 20, 2011 1:29 pm ] |
dont forget some 6.5 gears and some 26spine axles for the front |
| Author: | BlueSuzy [ Mon Jun 20, 2011 1:32 pm ] |
2" Body lift, 2" spring lift, pissorf the shackles. |
| Author: | samb0rg [ Mon Jun 20, 2011 2:29 pm ] |
shep wrote: ![]() i have just fitted 33s. have 100mm spring/shackle lift on the front and 125mm on the rear plus a 25mm body lift. also wt diffs with nt spacing, front diff moved about 50mm froward. and 6.5 trans case. still need to do a lot of cutting especially on the front. i don't think there will be much of the headlight bucket left when i am finished. I want to buy that Suzi. |
| Author: | BlueSuzy [ Mon Jun 20, 2011 2:36 pm ] |
ruf, corolla spring is in rear, 1" in total spring lift all round, 2"Bodylift, front is 30mm forward, Rear is 17mm rearward. Under size 33's. |
| Author: | sogone [ Wed Jun 22, 2011 8:57 am ] |
How did it go with rubbing Blue? |
| Author: | BlueSuzy [ Wed Jun 22, 2011 10:46 am ] |
Hammered all seams and headlight buckets. Rubbed alittle but didnt cut the tyres. |
| Author: | shep [ Wed Jun 22, 2011 10:47 am ] |
samb0rg wrote: shep wrote: ![]() i have just fitted 33s. have 100mm spring/shackle lift on the front and 125mm on the rear plus a 25mm body lift. also wt diffs with nt spacing, front diff moved about 50mm froward. and 6.5 trans case. still need to do a lot of cutting especially on the front. i don't think there will be much of the headlight bucket left when i am finished. I want to buy that Suzi. haha trust me ya dont |
| Author: | ajsr [ Wed Jun 22, 2011 10:50 am ] |
BlueSuzy wrote: ![]() ruf, corolla spring is in rear, 1" in total spring lift all round, 2"Bodylift, front is 30mm forward, Rear is 17mm rearward. Under size 33's. dont these tyres run at about 31.5" on a 33?? |
| Author: | BlueSuzy [ Wed Jun 22, 2011 12:56 pm ] |
31.9 |
