http://auszookers.com/forum/
92 Vit G16B Left engine mount broke. Easiest way to replace?
http://auszookers.com/forum/viewtopic.php?f=5&t=23078
Author:  fluffoffal [ Mon Jun 20, 2011 10:48 am ]
Post subject:  92 Vit G16B Left engine mount broke. Easiest way to replace?
Hi guys, just wondering what the easiest way to replace the left engine mount on my 92 Vitara. (G16B)
I don't have access to a hoist but have an engine cranne handy.
What's the easiest way to replace the broken mount?
Many thanks, Steve.
Author:  matty_wall [ Mon Jun 20, 2011 10:58 am ]
Post subject:  Re: 92 Vit G16B Left engine mount broke. Easiest way to replace?
undo the bolts and lift the engine up with a jack..
pretty much how i did mine from what i remember
Author:  fluffoffal [ Mon Jun 20, 2011 11:02 am ]
Just jack it up from the sump? Then just slide out the broken mount?
Is there enough clearance?
Author:  skyman [ Mon Jun 20, 2011 11:36 am ]
There should be two spots to hook the crane to from above. Loosen up and unbolt yer mounts, use the crane to lift 'er up and stuff a new Mount in. Easy as with a engine crane.
Without a crane just jack 'er up from below.
Author:  matty_wall [ Mon Jun 20, 2011 11:51 am ]
yep.. exactly what i did.. knew i forgot something
Author:  steak_knife [ Tue Jun 21, 2011 7:01 am ]
Put a bit of wood on the jack to distribute the weight a lil better...
