It is currently Tue Oct 27, 2026 3:41 am
Post Posted: Mon Jun 20, 2011 10:48 am
Hi guys, just wondering what the easiest way to replace the left engine mount on my 92 Vitara. (G16B)
I don't have access to a hoist but have an engine cranne handy.
What's the easiest way to replace the broken mount?
Many thanks, Steve.
Vehicle: SJ51T
Post Posted: Mon Jun 20, 2011 10:58 am
undo the bolts and lift the engine up with a jack..
pretty much how i did mine from what i remember
Post Posted: Mon Jun 20, 2011 11:02 am
Just jack it up from the sump? Then just slide out the broken mount?
Is there enough clearance?
Post Posted: Mon Jun 20, 2011 11:36 am
There should be two spots to hook the crane to from above. Loosen up and unbolt yer mounts, use the crane to lift 'er up and stuff a new Mount in. Easy as with a engine crane.
Without a crane just jack 'er up from below.
Vehicle: SJ51T
Post Posted: Mon Jun 20, 2011 11:51 am
yep.. exactly what i did.. knew i forgot something
Post Posted: Tue Jun 21, 2011 7:01 am
Put a bit of wood on the jack to distribute the weight a lil better...
Users browsing this forum: No registered users and 234 guests
