It is currently Thu Oct 22, 2026 4:58 am
Post Posted: Wed Jun 22, 2011 5:29 am
Hi all
I am going to use a 75 series landcruiser power steering box in my Sierra
I just wanted to know if the 1.6 Vitara power steering pump I have
Will have enough flow/ pressure for the landcruiser box to work correctly or would I be better off with a v6 commodore power steering pump as it still users the multi rib pulley
F#%ING [P] PLATER
 Profile YIM
Post Posted: Wed Jun 22, 2011 5:35 am
At a guess I would say no. Someone might have a conflicting opinion though
Post Posted: Wed Jun 22, 2011 6:28 am
It will work fine.
Depends on the size of the rubber you intend to run though.
Rob is running 60 series p/s box with baleno pump and has been doing the job for years. He is however going to upgrade.
I guess what im saying is it will work but is not the best tool for the job.
Post Posted: Wed Jun 22, 2011 6:54 am
I assume you know the box mounts way further back on the chassis, so axle and bumpstop position, shock mount location etc will all be effected.
Post Posted: Wed Jun 22, 2011 6:58 am
canberramav wrote:
It will work fine.
I will only be running 35s
Thanks for the info using the 1.6 will make it a bit easier
F#%ING [P] PLATER
 Profile YIM
Post Posted: Wed Jun 22, 2011 7:02 am
I'm my application the box will be mounted further forward then the Sierra box
I will have no problems with my bump stops or shock mounts because I have already cut them all off
Will be making new ones when everything is position correctly
F#%ING [P] PLATER
 Profile YIM
Post Posted: Wed Jun 22, 2011 7:25 am
Huh?
The pitman arm on an LC box is forward[/] facing. That means the box has to be mounted about 12" further [i]back in the chassis to get the drag link in the same place.
Just making sure you knew that - your response sounded like you didn't.
Personally, I think they are a bad box to use in a sierra, but I'm aware it's been done.
Post Posted: Wed Jun 22, 2011 7:29 am
I am using a 75 series landcruiser box they are not foward facing I am using the 75 box to suite my diffs
F#%ING [P] PLATER
 Profile YIM
Post Posted: Wed Jun 22, 2011 8:07 am
So it is - owned!
OK, in that case make sure you won't be all over it with your tyres then - that's a lot of bulk to put right where you are putting the tyre.
LHD IFS hilux box FTW! - prefer inside the chassis rail for neatness.
Post Posted: Wed Jun 22, 2011 8:23 am
So it is - owned!
If clearance becomes a problem I will adjust the steering stops or add wheel spacers
The reason I am sticking with the 75 series box is
I already have it and the have order the high steer to suite
F#%ING [P] PLATER
 Profile YIM
Post Posted: Wed Jun 22, 2011 9:20 am
I had a 80 series box on my old zook and used a el falcon pump it turned my 37's fine never had a problem with it
 Profile YIM
Post Posted: Wed Jun 22, 2011 10:41 am
My lwb will run lux ifs box, lux diffs. It will rub only slightly with 15x8 -19 rims, and 35x12.5's. I have to adjust steer stops for other reasons.
Users browsing this forum: No registered users and 331 guests
