| Author |
Message |
94BAZOOKA
Joined: Mon Jan 17, 2011 8:40 am Posts: 537 Location: central coast NSW
 Posted: Wed Jun 22, 2011 5:29 am |
Hi all
I am going to use a 75 series landcruiser power steering box in my Sierra
I just wanted to know if the 1.6 Vitara power steering pump I have
Will have enough flow/ pressure for the landcruiser box to work correctly or would I be better off with a v6 commodore power steering pump as it still users the multi rib pulley
_________________ F#%ING [P] PLATER
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Wed Jun 22, 2011 5:35 am |
At a guess I would say no. Someone might have a conflicting opinion though
_________________ Shep is a closet jimny lover!!!!
canberramav
Joined: Mon Jun 01, 2009 11:30 pm Posts: 643 Location: Canberra
 Posted: Wed Jun 22, 2011 6:28 am |
It will work fine.
Depends on the size of the rubber you intend to run though.
Rob is running 60 series p/s box with baleno pump and has been doing the job for years. He is however going to upgrade.
I guess what im saying is it will work but is not the best tool for the job.
Gwagensteve
 Posted: Wed Jun 22, 2011 6:54 am |
I assume you know the box mounts way further back on the chassis, so axle and bumpstop position, shock mount location etc will all be effected.
94BAZOOKA
 Posted: Wed Jun 22, 2011 6:58 am |
canberramav wrote: It will work fine.
I will only be running 35s
Thanks for the info using the 1.6 will make it a bit easier
94BAZOOKA
 Posted: Wed Jun 22, 2011 7:02 am |
Gwagensteve wrote: I assume you know the box mounts way further back on the chassis, so axle and bumpstop position, shock mount location etc will all be effected.
I'm my application the box will be mounted further forward then the Sierra box
I will have no problems with my bump stops or shock mounts because I have already cut them all off
Will be making new ones when everything is position correctly
Gwagensteve
 Posted: Wed Jun 22, 2011 7:25 am |
Huh?
The pitman arm on an LC box is forward[/] facing. That means the box has to be mounted about 12" further [i]back in the chassis to get the drag link in the same place.
Just making sure you knew that - your response sounded like you didn't.
Personally, I think they are a bad box to use in a sierra, but I'm aware it's been done.
94BAZOOKA
 Posted: Wed Jun 22, 2011 7:29 am |
I am using a 75 series landcruiser box they are not foward facing I am using the 75 box to suite my diffs
Gwagensteve
 Posted: Wed Jun 22, 2011 8:07 am |
So it is - owned!
OK, in that case make sure you won't be all over it with your tyres then - that's a lot of bulk to put right where you are putting the tyre.
LHD IFS hilux box FTW! - prefer inside the chassis rail for neatness.
94BAZOOKA
 Posted: Wed Jun 22, 2011 8:23 am |
Gwagensteve wrote: So it is - owned!
If clearance becomes a problem I will adjust the steering stops or add wheel spacers
The reason I am sticking with the 75 series box is
I already have it and the have order the high steer to suite
jimbo_jones
Joined: Sat Jul 19, 2008 11:30 pm Posts: 4361 Location: gong
 Posted: Wed Jun 22, 2011 9:20 am |
I had a 80 series box on my old zook and used a el falcon pump it turned my 37's fine never had a problem with it
BlueSuzy
 Posted: Wed Jun 22, 2011 10:41 am |
My lwb will run lux ifs box, lux diffs. It will rub only slightly with 15x8 -19 rims, and 35x12.5's. I have to adjust steer stops for other reasons.
