Hi. Was wondering if anyone can tell me where to buy a good quality 2" bodylift kit for a LWB vitara from? Preferably one that comes with brackets for front and rear bumper relocation. Oh yeah, I have an ARB bullbar. Would that be more complicated to re-mount than a stock bumper?
Also, do you need to modify the gear shifters with a 2" body lift?
Thanks in advance.
Joined: Wed Dec 08, 2010 7:16 am Posts: 941 Location: Shidoni!
Posted: Wed Jun 22, 2011 7:01 am
Rear bumper relocation is quite simple im sure if your capable of installing a body lift yourself, you should be able to sought out the rear Bar support. as for the front...
invest in a bullbar and modify that to the right height
Cool. I already have an arb steel bullbar. Shouldn,t be too hard to modify with a grinder and a weld or two.
Posted: Wed Jun 22, 2011 9:20 am
damn straight... id go with Two on the welds being that there is 2 brackets you need to modify
I used a bit of 25mm RHS, welded 2 pieces together, then welded that to the bar support. then a bit of threaded rod up the guts to hold the bar support on
Users browsing this forum: No registered users and 431 guests
