| vitara 1.3 http://auszookers.com/forum/viewtopic.php?f=5&t=23190 |
| Author: | shay [ Thu Jun 23, 2011 11:40 pm ] |
| Post subject: | vitara 1.3 |
i thought i read vitaras came out 1.3 if so was it the same motor as sierra q2could i swap the sierra motor to the vitara and vitara to the sierra ,both are carb 16a 13a . i know its arse about thanks |
| Author: | tanshi [ Thu Jun 23, 2011 11:50 pm ] |
| Post subject: | Re: vitara 1.3 |
they may have overseas, but i am pretty sure you wont find a g13 powered vitara over here |
| Author: | shay [ Fri Jun 24, 2011 12:08 am ] |
thanks tanshi its just that ive got a vitara a drover and a gti swift sitting here wondering what stupid things to do..my crazyest idea is gti swift on top of a vitara and turning the motor around |
| Author: | sogone [ Fri Jun 24, 2011 12:10 am ] |
That doesn't make sense ^^. |
| Author: | shay [ Fri Jun 24, 2011 12:21 am ] |
some how putting the swift body on a vitara chasis using the gti motor. i live on a hundred acres |
| Author: | jonno_racing [ Fri Jun 24, 2011 12:22 am ] |
the gti/1600 is a bad combination. it looses to much compression to be good, it does suit boost tho... |
| Author: | shay [ Fri Jun 24, 2011 12:39 am ] |
its a 1.3 gti in the swift..it would have to mate up to the vitara box or use sierra box behind gti to mate to vitara some how i am presuming,more like dreamin haha |
| Author: | shay [ Fri Jun 24, 2011 1:38 am ] |
| Author: | sogone [ Fri Jun 24, 2011 2:00 am ] |
Why wouldn't you need a loom? I think you've confused ya self :\. |
| Author: | BlueSuzy [ Fri Jun 24, 2011 2:12 am ] |
Vitara motor with adaptor to drover box, Run Vit wiring loom GTI motor with no adaptor to drover box, cut out the firewall as its a farm rig, run GTIwiring Loom. Keep vit as is and go nuts. Drive over the swift body |
| Author: | shay [ Fri Jun 24, 2011 2:49 am ] |
| Author: | SierraDan [ Fri Jun 24, 2011 3:17 am ] |
| Author: | BlueSuzy [ Fri Jun 24, 2011 3:33 am ] |
SierraDan wrote: :crazy:
I concur.
| Author: | Fatzook [ Fri Jun 24, 2011 6:01 am ] |
After reading this thread I'm convinced that you predominantly use your 100 acre property for farming skunk. |
| Author: | atari4x4 [ Fri Jun 24, 2011 7:08 am ] |
Fatzook wrote: After reading this thread I'm convinced that you predominantly use your 100 acre property for farming skunk.
SA - Growing all the way |
| Author: | FullyZooked [ Fri Jun 24, 2011 4:13 pm ] |
Marijuana farming no doubt? Little bit on the side? |
